-   -   new bathroom sink drain leaks (http://www.diychatroom.com/f7/new-bathroom-sink-drain-leaks-152908/)
pang 08-07-2012 09:41 AM
1 Attachment(s)
I installed a new vanity top in bathroom yesterday. It got leak just at top of tailpiece. Not sure where is wrong. I took a picture and attached here.
joecaption 08-07-2012 10:24 AM
Was there a gasket under the lip inside the sink where the pop up slides in?
There needed to be a gasket or plumbers puddy.
If there was then try applying some teflon pipe dope to the threads where that nut is under that big rubber washer.
pang 08-07-2012 08:30 PM
I wrap some teflon tapes around threads. It make leak nearly stop, but still tiny leak there :-( does putty work better on threads?
TheEplumber 08-07-2012 08:39 PM
199 Attachment(s)
I hate plastic tailpieces :furious:
Get a small can of this. IMO works better then tape or putty
http://www.homedepot.com/buy/plumbin...l#.UCHCdvZlRZc
Apply it to all mating surfaces and threads.
Alan 08-07-2012 09:06 PM
I hate those plastic pieces of s$%^ as well.
More than likely it's not the tailpiece but it's coming down the threads between the gasket and the popup assembly.
What we do :
1 : Lower the nut all the way down
2 : lower the gasket all the way down
3 : run a heavy bead of DAP 50 year caulking around the threads just above the gasket
4 : Re tighten the nut, and the gasket will push the DAP into the threads all the way up.
pang 08-08-2012 09:57 AM
It is the simplest way and make lot of sense, I will try it. Thx!
What we do :
