New Bathroom Price - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2006, 10:24 AM   #1
New Bathroom Price
I have the opportunity to remodel a bathroom after the customer had seen my quality work, but I dont want to short change myself with the cost. Here is a breakdown:
5x8 bathroom, full gut job, rotted drywall throughout, Will be replacing with durock, I will be also be replacing a new cast iron tub, new toilet, vanity, sink, tiling full shower to ceiling and half wall around bathroom, grout, sealing the grout, installing new plumbing, gfci receptacles, lighting, porcelain corner shelves, the whole shabang!
I was then asked to construct a pass thru bar opening around 4x7 feet from the kitchen to the living room. Then remove exterior sliding doors and intall with exterior french doors, and also replace the main front door and sidelight while they have me. One more thing reocate water heater in garage to make room for wall to be pushed back a few feet to allow a refridgerator to slide in to sit flush with the existing wall.....
I only need labor price, I will be delivering everything. I was thinking 7000
Thanks guys.
Natural`ontractor is offline   Reply With Quote
Old 10-08-2006, 10:30 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
How long will this take you, mutiply that by your hourly rate, there is your labor cost.
Ron The Plumber is offline   Reply With Quote
Old 10-08-2006, 10:32 AM   #3
I was thinking 7000
Old 10-08-2006, 10:34 AM   #4
Journeyman Plumber
If that is what you come up with, then that is what it will be.
Old 10-08-2006, 10:35 AM   #5
whats your hourly Ron?
Old 10-08-2006, 10:36 AM   #6
Journeyman Plumber
Eighty Five
Old 10-08-2006, 11:38 AM   #7
I blame ProWallGuy
Rewards Points: 150
You need to calculate your own numbers and start from there. using someone elses numbers is a sure way to go bankrupt.
Try this as a primer.
Double A is offline   Reply With Quote
