New Bathroom In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2009, 01:05 PM   #1
new bathroom in basement
Need to help put bathroom in basement.Bathroom is 18' from main stack.Sewer line runs under cement thru area where bathroom is going and exits to city sewer.Looking to dig up sewer line and tee into main sewer.Trouble is the venting,cannot vent directly above tub/toilet area as living room is above.How far sideways can I run vent line in the basement ceiling until I can find a spot to go vertical in a closet on the main floor and thru to attic and roof.And what is the minimum size of plumbing I can use for vent line?
buzz2234 is offline   Reply With Quote
Old 01-13-2009, 05:54 PM   #2
In the basement you have to run your vent vertical until you pass 42" from bottom of basment floor, they you can use elbows to run horizontal until you find a good spot to run vertically up through to the first floor. If you are adding just a standard bath(toilet, lavatory, and shower) a 2" vent is fine.
zosoplumber is offline   Reply With Quote
Old 01-14-2009, 09:26 AM   #3
thanks, seem to be tough to interpret the code.Yes it will be tub,toilet ,sink .some suggest that the vent had to be the same size as the 3" drain line the toilet would be dumping into.Is there a maximum horizontal length you can go before going vertical again?wouldn't want flush the toilet and suck the sink and tub p-traps dry.
Completing a roughed in basement bathroom Bob in St. Louis Plumbing 8 11-18-2011 12:12 PM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 02:56 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
