New Bath Waste Line Doesn't Leak, Yet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2013, 12:06 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 03-24-2013, 04:33 AM   #17
Roofmaster
Rewards Points: 2,210
Well, if you finish installing the overflow, and fill the tub right over the top of it, and it does not leak, well then I guess it is acceptable. Mine is not perfectly centered either, and it does not leak, so I haven't fixed it yet. If it leaks, I will. I figure Im off center, so maybe my drain should be too.
Calm down, have a JD Black over crushed ice.
Old 03-24-2013, 11:54 AM   #18
Rewards Points: 866
I am with you. Bottom line - it does NOT leak. Nor did the water level of a full tub drop any measurable amount over 14 hours. That tub is tight! Also, I really think the plumber that came out was diligent and was doing his best. This was a referral from my wife's boss and no apprentice. I don't know what and don't need to know, but something about the location made it a *****. He mentioned how had a joist not been so close to the p-trap it would have been much easier.
As for the alcohol! I am a very light drinker, but the last few nights I have had a good size glass of wine and last night the wife and I visited a nice sea food place and I did enjoy a vodka and tonic. Doubt it will ever happen, but would like to have a few rounds with you guys some day.
Klawman is offline   Reply With Quote
Old 03-24-2013, 12:25 PM   #19
Rewards Points: 166
Originally Posted by Klawman View Post
So far it has not leaked but then overflow pipe is way off centger and possibly already slipping down a bid. To mate it to the tub he used a really thick seal that was kind of conically shaped.
I had similar concern with a bathtub overflow looking funky. I posted here. Turned out to be OK.
Bathtub overflow plate. Is this a problem?
New bath waste line doesn't leak, yet.-111.jpg   New bath waste line doesn't leak, yet.-222.jpg   New bath waste line doesn't leak, yet.-333.jpg   New bath waste line doesn't leak, yet.-444.jpg   New bath waste line doesn't leak, yet.-555.jpg
Minus08 is offline   Reply With Quote
Old 03-24-2013, 12:51 PM   #20
Rewards Points: 866
Thanks, Minus08. Your problem is almost a carbon copy of mine with the only difference being that your overflow is centered high and to the right and mine is low and to the left. I am a lot less concerned about this issue and have begun cleaning up the mess left by the original contractor so some people can get in to do the tiling and drywall.
Old 03-24-2013, 05:17 PM   #21
Rewards Points: 1,954
Looks much better then what you had before Klaw.
Old 03-31-2013, 11:37 AM   #22
Rewards Points: 866
Cutting Brass Pipe For Spout
I am now hooking up the new bath spout. The thread on the old brass 1/2" pipe is very slightly goobered up on the end that went in the wall. I think the guy I canned started it in cross threaded. Anyway, the end that threads into the far end of the spout looks fine. Should I just turn it around and insert the outside end in the wall or get a new one cut at HD?
Thanks and Happy Easter to all.
Old 03-31-2013, 04:14 PM   #23
Roofmaster
Hey Klaw, Happy Easter to you Too, Check out this link from Arsinik (sp) Maybe this will help?
https://www.buyeagle.biz/flex-916
The Following User Says Thank You to jagans For This Useful Post:
Klawman (03-31-2013)
Old 03-31-2013, 04:59 PM   #24
Rewards Points: 866
Thannks, Jagans. Not too concerned about the drain line, but if I ever have reason to pull the large pantry on the opposite side of the wet wall I will get in there and line that sucker up on the money.
Perhaps tomorrow I will enclose the tub with some sliding doors and caulk the **** out of it.
We take it easy on Easter. I like these low pressure holidays. The boss usually cooks a nice meal. Today it is a simple pork roast, and we have a bottle of wine and a few beers.
The Following 2 Users Say Thank You to Klawman For This Useful Post:
djlandkpl (03-31-2013), oh'mike (03-31-2013)
Help with small leak in bath sink drain Binski Plumbing 6 12-03-2011 09:54 PM
air conditioning leak in insulated copper line, in attic? johnfrmsport HVAC 3 07-18-2011 05:40 PM
New acrylic bath tub install weird leak Panch Plumbing 5 08-23-2009 05:23 PM
waste arm leak denverlynx Plumbing 5 11-25-2008 04:18 PM
