New Bath Faucet With Flow Restriction - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2013, 11:51 PM   #1
Rewards Points: 290
new bath faucet with flow restriction
I just picked up a new Delta bathroom sink faucet (three piece style). Some parts such as the valves appear well built, but other parts do not. One item is the spigot supply pipe is not brazed or epoxied in, but is a very loose slip fit with a single o-ring. Another is the valve & spigot are connected by a three-way hose with white plastic snap-on connectors instead of threaded metal fittings. I have never seen this type of fitting and I'll bet it is specific to Delta. There also appears to be flow restriction built into these connectors rather than just at the aerator. No easy way to drill it out either. This is a real annoyance since that bathroom already has hot water issues due to long runs and restricted flow. Before this turns into a rant about Big Brother, can anyone vouch for the longevity of these new designs, or should I look elsewhere?
tns1 is offline   Reply With Quote
Old 10-31-2013, 12:21 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
The connection methods are not specific to Delta, other top brand names use simalar methods. I have had no problems with them- except an occasional pinched o-ring caused by installer error
Flow restrictions are due to water conservations laws...... they don't want them removed.
Old 11-18-2013, 01:19 AM   #3
Rewards Points: 290
I have installed the faucet in question. The water flow is fine for a bathroom sink, so the hose restrictors do not seem unreasonable. If this were a kitchen sink, I might complain.
Looking at specs for different brand sink faucets shows flow rates that vary from 1.8gpm to 2.5gpm. I would have thought all the restrictors would be standardized to one value. Anyway, I purchased one of the higher flow faucets for my future kitchen remodel in case the flow rate standards go to even lower by the time I start the project.
No flow from Delta Monitor 1400 faucet after reinstallation StubbornFaucet Plumbing 14 10-09-2015 11:00 PM
Bath Faucet Frank Pipolo Plumbing 3 06-26-2012 07:35 PM
Bath Faucet Cartridge Installation sobro Plumbing 7 06-14-2012 05:35 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Air Lock in hot water line? tqwood Plumbing 3 03-16-2008 12:26 AM
