New Basket Strainer In Place - But Now A New Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2014, 09:00 PM   #1
Rewards Points: 24
New Basket Strainer in Place - but now a new problem
Thanks to everyone (especially E) for helping with my detached sink drain. As you can see the new one is almost installed.
The problem now, is that the old nut has bad threads and will not attach to base of the newly installed basket. Fortunately, a new nut, which fits perfectly, came with the basket strainer. However, I do not know how I am supposed to get the new nut onto the tailpipe in place of the old nut! At the very top of the tailpipe is a plastic ridge that seems too large to get the metal nuts past. Should I just force the metal nuts over the ridge, or am I missing something?
Thanks in advance!
New Basket Strainer in Place - but now a new problem-under-sink.jpg   New Basket Strainer in Place - but now a new problem-pipe-copy.jpg
S_Jeff is offline   Reply With Quote
Old 04-10-2014, 09:16 PM   #2
Rewards Points: 142
Originally Posted by S_Jeff View Post
Should I just force the metal nuts over the ridge, or am I missing something? Thanks in advance!
No. Just slide everything off and on from the other end without the ridge. Just make sure everything goes back on the right way or you will have leaks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
LateralConcepts (04-10-2014)
Old 04-10-2014, 09:43 PM   #3
DIY staff
Rewards Points: 7,174
Remove the nylon ring and replace the nut---
I seldom reuse old parts--that tube is called a tail piece ---it is always wise to use new nuts and washers---get it done with what you have--but if it leaks--head to the store and buy a new tail piece--plastic nuts and a new washer---
jmon (04-10-2014)
Old 04-10-2014, 10:40 PM   #4
Owner
LateralConcepts's Avatar
I agree with using new parts. Do it either way, but there should also be a flat-top washer on top of that flanged tailpiece.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
jmon (04-11-2014)
Marble Farmhouse Sink Strainer Master Brian Plumbing 5 04-11-2014 05:59 PM
Downdraft range vent exhaust placement problem Docman General DIY Discussions 2 08-02-2013 04:26 AM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
