New Basement Sink Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 12:28 PM   #1
Question
I am new to this forum, and posted this q. in the 'intro' thread,
but realized it belongs here instead.
Does anyone know where I can find an online, straightforward plumber's code for MA ? I want to
plumb a utility sink into my basement, but need to make
sure I tap the water lines (copper) and do the drain (PVC) properly.
I can sweat the pipe and glue the pvc, but I don't know
what intake pipes I should/should not draw the water from (i.e. take
them right off of the clothes washer pipes or only off of the main
intake pipes?), what the angles for the drain should be, and whether I can tie the drain for the sink into the existing drain-pipe for the washer
OR should the sink drain go into the stack independently?
Thanks.
handymanguy is offline   Reply With Quote
Old 02-08-2009, 09:20 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,344
Not straightforward but most of the code books are here:
http://bulk.resource.org/codes.gov/
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-14-2009, 09:27 AM   #3
This is great. All the code in 1 place. Thanks for the link !
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Tips for HEAVY sink install Sarah24 Plumbing 3 12-04-2008 07:01 PM
vanity sink install aulii1 Plumbing 2 11-28-2008 12:43 PM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
