Is NeverScrub Automatic Toilet Bowl Cleaner Bad For Any Part Of My Plumbing System? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2012, 06:05 PM   #1
Rewards Points: 12
Is NeverScrub Automatic Toilet Bowl Cleaner bad for any part of my plumbing system?
...other than the toilet tank? However, since this particular product ( is installed in the pipe that goes into the toilet bowl, as opposed to just sitting in the toilet tank, it is supposed to keep your rubber and plastic parts from degrading.
That said, will the plastic pipe degrade? Is there any danger to any other part of my system, pipes, the main stack, etc. I don't know all the terminology. Basically I am concerned about everything from the toilet to where my lines enter the sewer system (we use public services, not a septic tank).
If it helps, the house was built in the 1890's; I don't know when the plumbing was installed. But let's just assume that it's a mixture of PVC, galvanized, copper, cast iron and lead.
bigdaddydavy is offline   Reply With Quote
Old 11-28-2012, 06:56 PM   #2
I'm pretty sure toilet manufacturers will still use it as an excuse to void the warranty. But I don't think they do any harm.
Ishmael is offline   Reply With Quote
Old 11-29-2012, 11:37 AM   #3
Special User
Rewards Points: 1,230
City water companies always put chlorine (or chloramines) into your water supply, so everything in your toilet and drain system is already designed to handle chlorine.
Admittedly toilet cleaner products add a higher concentration of chlorine, but I'd imagine that before the concentration got high enough to do damage, the smell would drive you right out of the bathroom.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
Toilet bowl shims rjniles Plumbing 2 08-23-2007 05:06 PM
