Nervous About Welding Drain Pipe For Water Heater T/p Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2012, 01:10 AM   #1
Rewards Points: 682
Nervous about welding drain pipe for water heater t/p valve?
Every time I install a water heater I worry about welding the drain pipe attached to the pt valve. I'm thinking the acid smoke from the heated flux will rise up inside the tube and damage the rubber gasket of the p/t valve. Is my concern groundless?
darsunt is offline   Reply With Quote
Old 04-01-2012, 05:08 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
I assume you mean soldering not welding. Your concerns are groundless.
Coastal South Carolina
Old 04-01-2012, 06:05 AM   #3
Rewards Points: 1,216
Just buy the pre made one's from HD or Ls. No soldering needed.
COLDIRON is offline   Reply With Quote
Old 04-01-2012, 11:10 PM   #4
Rewards Points: 682
Yes, I mean soldering. I won't worry about it, it looks from the drain pipes I've seen that everyone does it.
Many of the drain pipes have to run a convoluted path to get from the p/t valve to the outside where they are supposed to go. I can't think of a cost effective way to run them except by soldering.
Old 04-01-2012, 11:23 PM   #5
Coldiron gave you a cost effective way. Buy the plastic thin walled PVC pipe from HD (~$6 for a 54" piece). Put some teflon tape, screw in and voila, done.
By the by, the pipe should never be hard piped all the way outside. Pipe down to around 1" or 2" above the rim of the floor pan. That way owner is more likely to notice if there's water coming out of the T&P.
VIPlumber is offline   Reply With Quote
Old 04-01-2012, 11:29 PM   #6
Rewards Points: 14,312
I agree it seems logical to run it outside, and I've even done it that way my self but it will not meet code to do it that way.
Anytime your soldering any valve it needs to be opened.
Old 04-03-2012, 04:27 PM   #7
Rewards Points: 682
I think code around here (southern California) requires venting the drain of a w/h outside. Otherwise no one would go to the trouble of doing it.
Old 04-03-2012, 08:37 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 922
Just goes to show how codes vary.
I cannot use PVC for a t&p line and it must pipe directly outside or to an approved drain such as FD, Sink, hub drain, etc. (not to the pan)
Pans are required in most applications and must follow the same discharge rules as the t&p.
A lot of homes here have basements and the t&p's are not piped out. In this case we can usually "grandfather" the install of the replacement heater.
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
valve retrieval in a drain houston81 Plumbing 1 07-07-2010 04:33 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
