Neo Angle Shower Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2009, 06:05 PM   #1
Federico
fcmazz's Avatar
Exclamation
DIY'ers,
I am in the process of installing a neo angle shower in one bathroom in an upstairs cabin. One of those showers that Lowes or H-Depot sells. I have read the instructions but still confused. Was looking to see any of you have installed one and can share the info ; pictures of your project would be great.
So far I roughed in the drain hole, tiled the floor and put in the DensGuard Tile Backer board on the wall. I have 2 panels in question that come with the shower. They are really flimsy and skinny. How are these panels installed on the wall? How do the panels line up and sync with the base of the shower? Anyone have problems with the installation, after project leaks etc...
Appreciate the feedback.
fcmazz
fcmazz is offline   Reply With Quote
Old 09-08-2009, 06:33 PM   #2
Knucklez's Avatar
Rewards Points: 942
i think i did a similar project?
my shower project, denshield backerboard, tiled walls
but i did not buy the walls that came with (optional). pretty straight forward project. the instructions on how to set the drain lock nut was wrong so that was frustrating.
one thing i wished i did differently was to install the tub faucet for the feet. just to relieve the water pressure in the line after you're done showering.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-08-2009, 06:36 PM   #3
Knucklez's Avatar
Rewards Points: 942
oh.. what i found with my neo angle was that once i adjusted the feet so it was level on all sides, i stood on it. and i stood with my feet together at all different locations and found that if i stood at the corner it would actually tip the base over. so that tells me it is not designed perfectly balanced.. so i put a 1/2 bag of mortar in that corner for support. also put a large doughnut shaped pile of mortar on the floor circling the drain hole (with 4" clearance). then placed the based down on it and squished it good. put some weight on the base. then waited a couple of days for it to dry and then continued on with the install.
its not going anywhere now!
Knucklez
Old 09-13-2009, 06:41 PM   #4
Federico
fcmazz's Avatar
Thank you Knucklez for your input. Your project looks good. Keep up the good work.
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 08:23 PM
Install of shower insert 68MHJCs Remodeling 1 09-08-2009 06:29 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
