Neighbors Tapped Into My Waterline? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2012, 07:15 AM   #46
Rewards Points: 2,494
ddawg had simplest solution. When you see his sprinklers on shut the water off to your house.
hammerlane is offline   Reply With Quote
Old 07-04-2012, 08:13 AM   #47
DIY staff
Rewards Points: 7,174
Get that camera---My guess---they just sneak into the yard when you aren't home and hook a hose onto your fixture--
Old 07-04-2012, 11:08 AM   #48
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Good idea. A game camera would work great for this.
Journeyman Plumber
Old 07-04-2012, 06:23 PM   #49
JOATMON
ddawg16's Avatar
Rewards Points: 796
Another good posibility......
If that is the case...the OP must be gone a lot and the other neighbors blind....if he was doing that, you would think 'someone' would see him.
ddawg16 is online now   Reply With Quote
Old 07-12-2013, 12:38 AM   #50
I would love to know how this issue was resolved. Did you catch the guy? Or did you find something else.
hoppyhere is offline   Reply With Quote
Old 07-12-2013, 07:34 AM   #51
Rewards Points: 1,214
I second that.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-17-2013, 12:47 AM   #52
Wow. I found this forum and thread after googling "neighbor water theft" because I might have a similar situation.
The water district called us about 4 months ago and informed us that our bill, normally $120, was tripled. They had caught the unusual usage and were checking it out.
I had no explanation. Except for the spinning leak detection dial on the meter, there were no signs of a leak even with everything turned off. I closed the ball valve to the house and left the irrigation system gate valve open, and the meter kept going. I closed the gate valve to the irrigation system - the meter stopped. Then I opened the valve to the house, and the meter was still stopped. I left the irrigation valve closed and our bill dropped to $88.
Now that summer is raging I have had to open the irrigation valve, and our bill hit $332, and today the bill came. $496!
We have an acre, so our irrigation system is fairly large. I have looked everywhere and dug a bunch of holes, followed pipes by trenching, replaced any fitting, pipe, or valve that had moisture around it, still the meter spins. Our yard looks like Gophersaurus has moved in.
I had a local leak detection company come out and for $250 they couldn't find anything. They said it would take at least 2 bottles of tracer gas to pressurize the system because the previous owner that installed it many years ago cobbled it together out of 3" PVC, 2" PVC, and anything else he could scrounge up. We said that we would hold off on the tracer gas.
Today when we got the bill for $496, we called the water district. They came right out and tried to help, and that's when the light went on.
At one time, our lot was part of a much larger parcel, and a well provided water to the irrigation. When the lots were split, the water was plumbed through our meter and since the well was on the other lot it fell into disuse.
I don't know the status of the pipe or where it is, but my neighbor's lot is nice and green and mine is rapidly drying out and dying.
If the pipe is still there and was merely shut off with a valve, it would be as easy as turning the handle to access our water.
I'm going to have to dig a trench along the property line to try to find the pipe, if it still exists. Or I could get some coat hangers...
MyronW is offline   Reply With Quote
Old 07-17-2013, 12:58 AM   #53
JOATMON
ddawg16's Avatar
Rewards Points: 796
The OP has not been on in over a year.....I guess we will never know.
Old 07-17-2013, 01:37 AM   #54
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Let us know what you find out.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-17-2013, 08:43 AM   #55
joed's Avatar
Rewards Points: 11,520
If you don't use the irrigation system then just leave the valve off.
Try disconnecting some of the joints you have exposed and capping them. Turn on the valve and see if the meter still spins. This way you can eliminate a section as the leak or prove them to be the leaky section.
Old 07-17-2013, 09:25 AM   #56
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
If your neighbor has a sprinkler system where you can see when he is watering his lawn, turn the water off and back on a couple of times to see if it affects his sprinklers.
Jim
Old 07-17-2013, 01:31 PM   #57
joed's Avatar
I believe you have a leak somewhere. You just need to find it.
Old 07-17-2013, 02:52 PM   #58
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,328
Originally Posted by joecaption View Post
If that was true, how come he's getting any water bill?
Parrellel connection??
MTN REMODEL LLC is offline   Reply With Quote
Old 07-17-2013, 03:50 PM   #59
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
I would bet you are pumping water down thr old well.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Alan (07-18-2013)
Old 07-18-2013, 02:37 PM   #60
That's what I'm thinking, too. Recharging the aquifer is not in my budget!
That would explain the constant flow. A direct connection would be intermittent.
Etiquette Question: Asking Neighbors to Contribute to Tree Removal jlpeifer Landscaping & Lawn Care 14 10-20-2011 05:33 PM
Lattice infront of neighbors satellite dish? DIYguy2000 General DIY Discussions 8 06-09-2010 10:29 AM
Help Burying a 250 foot waterline .. rugged terrain cdnjan Plumbing 1 09-28-2009 08:09 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 11:31 AM
simple frig waterline question weiside Appliances 6 08-01-2007 11:30 PM
