Need Urgent Help With Relocation Of Shower P Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2012, 10:30 PM   #16
Forgot to mention, the WYE is rolled to horizontal 90 for the 2" shower inlet as show in the picture. The WYE for the vent already downstream is rolled to a 45" with a pipe and 90 which points it right against the subfloor and joist on the left.
vetting is offline   Reply With Quote
Old 06-01-2012, 09:21 AM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by vetting View Post
So would this work? with vent going into the horizontal 2" 45 street elbow that I have running out of the 3" as long as the vent is sloped above the level of the P trap?
That wouldn't pass a plumbing inspection here.
Journeyman Plumber
Old 06-02-2012, 10:42 PM   #18
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
are you sure there is not enough room if cut that coup off flush to the hub then get a street 2x2x1 1/2 san tee then your p trap .Worse case a couple of street 22 on riser
wctekkk is offline   Reply With Quote
URGENT: Need Help with Shower Leaks myriam0109 Plumbing 8 03-06-2012 09:43 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
