Need some urgent help - need to fix this tomorrow.
Have a swanstone shower pan installed and since the drain location is in a different spot than the old shower pan, the entire P trap needed to be moved. There are a few problems.
The offshoot from from the 4" line is almost right under the shower pan opening. I rigged up a new P trap and 2 45s to offset it enough for it to line back up. I went to attach it and realized that I cut the stub on offshoot too short. I tried to glue it, but there just wasnt enough for it to grab onto.
Is there something else I can use? Can I even attempt to chip out the pipe sticking out of the offshoot that I cut to short to put a new 2" pipe in there? Or should I attempt to glue on a coupler and redo what i had assembled for the P trap?
Any suggestions for me? Please help because Im really in a jam.
Here is a picture of what I'm dealing with.
