-   -   Need urgent help with relocation of shower P trap (http://www.diychatroom.com/f7/need-urgent-help-relocation-shower-p-trap-145425/)
vetting 05-30-2012 10:47 PM
Need some urgent help - need to fix this tomorrow.
Have a swanstone shower pan installed and since the drain location is in a different spot than the old shower pan, the entire P trap needed to be moved. There are a few problems.
The offshoot from from the 4" line is almost right under the shower pan opening. I rigged up a new P trap and 2 45s to offset it enough for it to line back up. I went to attach it and realized that I cut the stub on offshoot too short. I tried to glue it, but there just wasnt enough for it to grab onto.
Is there something else I can use? Can I even attempt to chip out the pipe sticking out of the offshoot that I cut to short to put a new 2" pipe in there? Or should I attempt to glue on a coupler and redo what i had assembled for the P trap?
Any suggestions for me? Please help because Im really in a jam.
Here is a picture of what I'm dealing with.
http://remodel.myauctionlinks.com/showerptrap1.jpg
Alan 05-30-2012 11:18 PM
No vent?
:huh:
They make a tool for drilling the pipe out of a hub. You might be able to find one at the hardware store, or you might have to order one online.
http://www.google.com/products/catal...ed=0CGcQ8wIwAQ
vetting 05-30-2012 11:19 PM
Originally Posted by Alan (Post 932710)
No vent?
:huh:
The vent is about 2 feet further up the pipe - just out of the picture. It used to run right were the shower pan comes out so I already cut it out to move it. Just trying to figure out the P trap situation so I then can route the vent.
sanec1 05-30-2012 11:26 PM
I would take some coarse sandpaper and clean up the pipe in the hub and then put pvc primer on it and glue on a new coupling. You could also cut the whole ty out and install a new one by gluing short pieces of pipe into the ends. Then install it with rubber couplings. Fernco is a brand I have used. I see there is a fitting 90 in one side of the tee. You could also use a rubber coupling on the pipe stub.
wctekkk 05-30-2012 11:29 PM
shower drain
ok a question, were is the vent for the shower? and after that 3+2 y sorry for that that + i can't find a times button any way what's the 3" picking up? hopefully there's a vent for that fixture post another pic.I would like to give you some advice but not seeing a vent would mean a lot more work, however i do see what looks like a coupling there leaving even less room you can cut that coupling off flush to the 3+2 they sell a tool called ram bit they come in several sizes you need a 2" use a cordless drill and drill out inside the fitting then check if that will do it.If not then maybe a street 45 going Parallel to the 3" go past the shower and swing the trap back 180.But PLEASE POST MORE OF THAT DRAIN UP AND DOWNSTREAM.
wctekkk 05-30-2012 11:36 PM
shower drain
By the time i was replying i read the up dates i am slow the vent is not correct should be on the 2"
vetting 05-30-2012 11:41 PM
I wont have any more pics until tomorrow. The main pipe leads to the toilet. The vent is between the shower and the toilet.
Im starting to think using a ram bit is the way to go.
Run a 45 street along side the main and then tie in the Ptrap.
Do any big box stores sell ram bits?
vetting 05-30-2012 11:44 PM
How would there ever be room for the vent directly on the 2" to the shower?
Since the vent is upstream from the shower 2", I thought it was fine.
Alan 05-31-2012 09:18 AM
qrstuvwxyz
Alan 05-31-2012 09:19 AM
If the vent is between the shower and the toilet, then that vent is for the toilet. The shower should have it's own vent.
vetting 05-31-2012 09:47 AM
So where is the vent supposed to go with the limited space?
As of now, im planning on gluing a coupler on the stub piece. Then running an angle piece with a street elbow that will run parallel with the main. Then run a 45 down into the trap.
vetting 05-31-2012 12:54 PM
Found a local place that has a 2" ram bit - so going to go that route now. Just going to drill the pipe out and then put in a 45 degree street elbow to avoid any clearance issues. From there, I can configure the trap without using a bunch of fittings.
Alan 05-31-2012 08:27 PM
Welcome to laying out a plumbing system 101. :)
Your drain has to intersect a wall, so that it can be vented, and then the trap arm continued toward the location of the shower outlet.
vetting 05-31-2012 10:02 PM
There will be a vent line running up to the left of the shower pan outlet right up against the sub floor. Can I just T off the 2" shower pipe running horizontally off the horizontal 3" and then T it into that 1.5" vent that is running to further down the 3" for the toilet?
vetting 05-31-2012 10:16 PM
So would this work? with vent going into the horizontal 2" 45 street elbow that I have running out of the 3" as long as the vent is sloped above the level of the P trap?
http://remodel.myauctionlinks.com/sh...rap1vented.jpg
