Need Unusual Part For Faucet Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2011, 09:53 AM   #1
Question
Need unusual part for faucet installation
I am installing a new faucet but the threaded rods for securing the unit to the vanity are not long enough. I can't find a replacement -- maybe a metric size? It has a 28-thread count, but is smaller than 1/4". Any ideas where I might find the part I need?
Note: I'm converting an old piece of furniture into a bathroom vanity and so the unit is deep where I have drilled the hole for the faucet, which is why the mounting rods are too short. Can't move the whole at this stage, as I have tiled the top of the unit. Must find a way to secure the faucet in this spot. Any ideas?
FishLips is offline   Reply With Quote
Old 04-19-2011, 11:03 AM   #2
Rewards Points: 482
If it were me i would take the faucet out and go to a good plumbing supply house. They should be able to help. You will not find part's at the box's store's good luck
del schisler is online now   Reply With Quote
Old 04-19-2011, 11:12 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
I am making the assumption this is a piece of wood furniture that you have tiled the top to use as a vanity. From the bottom use a hole saw and enlarge the hole to a depth deep enough to let the existing mountain secure. After you get the hole saw deep enough, use a chisel to break out the wood core.
Since you have drilled the hole thru the vanity already it will be hard to keep a hole saw centered. Take 2 hole saw; a small one the size of the existing hole and a larger one to take out the wood you need relieved. Mount them on the same arbor. The smaller saw will keep the larger one centered in the hole.
Coastal South Carolina
Old 04-19-2011, 11:56 AM   #4
Thanks for the suggestion. I considered drilling a larger hole from beneath, however, the hole comes through a support beam. I think thinning this beam will weaken it too much; it is supporting stone tile and a marble sink, so is bearing a lot of weight. I don't want to risk it.
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 12:42 PM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
Kohler whirlpool installation bypass air switch Jet001 Electrical 1 04-29-2010 04:35 PM
Hot Tub/Spa Installation BigA Electrical 6 03-11-2010 08:12 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
