Need To Tap Into Water Supply - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2012, 02:35 PM   #1
need to tap into water supply
how do you tap into a water supply for foe a water purifying machine
hornfrog is offline   Reply With Quote
Old 07-08-2012, 03:06 PM   #2
Rewards Points: 14,026
A picture of where you plan to install it, and telling us what type plumbing you have would be a big help.
oh'mike (07-08-2012)
Old 07-08-2012, 03:37 PM   #3
Rewards Points: 6,652
Jump up and down on one foot, while waving one hand, that is opposite of the foot you are jumping on.
Old 07-08-2012, 09:22 PM   #4
Rewards Points: 582
use a pipe cutter cut out a small section of pipe install tee with valve for purifying machine turn water back on check for leaks
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
water supply layout wglord Plumbing 1 07-13-2009 12:07 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
