Old 06-06-2012, 10:11 AM   #1
Need some help with a vent on a double vanity
I have to move some plumbing due to framing for a 46" recessed medicine cabinet.
Here is the picture with the framing in progress.
The wall isnt a 2x6. Instead its a 2x4 with a spilt 2x4 on the back side of every stud making it about a 1/2 short of being a full 2x6. Any ways, Im leaving the split 2x4 on the back side and framing a king and jack stud with a 2x6 header on top. All of the wires are clipped onto the split 2x4 on the back side.
The prior vent ran about 8 inches way from the main stack you see on the left. It then T'd into the line from the double vanity. The problem is I cant run it through there any more due to the medicine cabinet. Is it ok to run it up and around the top of the header down the right side on the other side of the king/jack stud on the right and then T into the right side of the horizontal sink pipe in the wall. At what point should I enter the pipe - is it best to do it between the 2 sinks?
vetting is offline   Reply With Quote
Old 06-06-2012, 10:09 PM   #2
Doing it myself
Alan's Avatar
The way that is plumbed aint legal to begin with. . . . . .
Is it a load bearing wall?
Journeyman Plumber
Old 06-08-2012, 10:29 AM   #3
Master Plumber
Javiles's Avatar
and on top of that it looks like its back pitched
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 06-08-2012, 10:41 AM   #4
Thats just an optical illusion. Im replacing all of that pipe anyways.
Everything is now framed out to code and the vent is going to run up and over, down the right side, and tie into the middle of the horizontal.
The horizontal will have a sanitary T for the left and a long sweep on the right.
Old 06-08-2012, 08:16 PM   #5
Doing it myself
Alan's Avatar
That doesn't really sound right either.
A quick sketch would help.
Journeyman Plumber
New Roof marknok Roofing 4 08-06-2011 12:41 PM
Double sink vanity RobertBr Carpentry 4 07-31-2011 01:23 PM
Double wide ridge vent peterdelorme Roofing 1 07-26-2011 07:11 AM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
Shingling over ridge vent -details needed jogr Roofing 4 11-06-2009 06:47 PM
