Need Some Help Please With Drain Install!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2009, 09:12 PM   #1
Question
need some help please with drain install!!
ok here we go...i have a carport that i boxed in so i could have another room in my home...i have the washer and dryer on the other side of one of the walls and i want to cut into that wall and tap into the hot and cold water as well as the drain so i can add a sink in my added room...ok, i understand and know how to do the water part with no problem but my question is what is the best way to tap into the drain and install the p trap for the new sink?...first off there is about a 16" drop between the two rooms so i will be below the washer drain, and that is why i am asking about this before i start the task...my thoughts are just to find out what size the drain is and cut it and add a tee then tap in like that but does this sound ok or is there another way i should do this?? please help!
suthernkumfert is offline   Reply With Quote
Old 03-28-2009, 09:34 PM   #2
HVAC / Plumbing
put the trap just below the sink drain ( at the sink) You may want to use a combination fitting Instead of a tee.. Depending on your situation
kenmac is offline   Reply With Quote
Old 03-28-2009, 09:42 PM   #3
so it should not matter where i tap into the drain as long as i put the ptrap right under the sink? and what is a combination fitting?
Old 03-28-2009, 09:50 PM   #4
HVAC / Plumbing
No....looks like this..............I have no idea what you are going to tie into
Old 03-28-2009, 09:51 PM   #5
and also with me tapping into the drain for the washer below the washer input into the drain will i have a problem when the washer dumps its water down the drain with it sucking the water out of ptrap on the sink and sewer gases coming back up into the sink drain lines?
Old 03-28-2009, 09:53 PM   #6
oh ok...thanks for the pic...i plan to tie into the washer drain in the wall...is this ok?
Old 03-28-2009, 09:54 PM   #7
HVAC / Plumbing
Unless I'am missing something...
I don't see any problems as long as the plumbing is vented correctly... Only problem is if both are operating at the same time .. the washer drain may not be large enough...
Old 03-28-2009, 09:58 PM   #8
what is and how do i need to check to make sure it is vented correctly?
i dont know if it matters but i have never had a problem with the washer draining...so would that mean it is vented correctly??? and by adding a sink to drain could this make it not vented correctly?
Old 03-28-2009, 10:16 PM   #9
ok thats what i was thinking but i wanted to make sure...also...
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 09:20 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 04:45 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
Drain clean out requirements steve1234 Plumbing 2 11-20-2007 11:06 PM
