Need Some Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2007, 11:53 AM   #1
Need some help
I'm putting down tile floor in a bathroom, I had to remove 1/4" sub floor and those stick down tile. I'm using 1/4" hardibacker board and 1/4" tile. Do I need to adjust the height of the toilet flange?
Nick K is offline   Reply With Quote
Old 08-24-2007, 11:58 AM   #2
the hardibacker board went under the flange fine and there is still a little play. And it is a outside glued flange to abs plastic pipe. The flange has a small amount of rust but nothing that bad.
Old 08-24-2007, 12:32 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Should be fine, use extra wax is the toilet sets low into the floor.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-24-2007, 12:38 PM   #4
So do I tile around the flange or do I put the tile under the flange?
Old 08-24-2007, 12:44 PM   #5
Journeyman Plumber
Tile under if you can
Old 08-24-2007, 12:53 PM   #6
I think that I have enough room but how would I screw the flange down if I have the tile under the flange? Could I get away with leaving the flange on the hardibacker subfloor and using a larger wax ring?
Old 08-24-2007, 05:27 PM   #7
Send a message via AIM to Marlin
Ideally you want the flange on top of the floor. You can put it on your mud/cement floor, you may have to use two wax rings though (one with a horn and one without on top of it).
The two things you have to make sure of though is that the flange is sitting firmly on whatever floor you have it on and that it is screwed down. If you put tile under it you need to drill holes with a hammer drill or diamond drill bit and then screw it down.
I don't think this applies to you but if you have thick mud and can't reach the sub-floor or are on a slab you have to drill holes with a hammer drill and use concrete anchors which look and work just like Sheetrock anchors (they are not interchangeable though).
Marlin is offline   Reply With Quote
