Old 10-26-2009, 09:28 PM   #1
Default Need some advice plz....
hi guys,
I need some advice..
I have a town house for rent and yesterday they called me and told me that they think the sewer is clogged.. they told me when they flush the toilet.. the toilet would not flush and water start filling up..
I called my uncle..he is kinda like a handyman and he has a commercial plumbing machine..
he tells me that the pipes inside the house are okay.. but the one that goes out to the street is clogged.. and he tells me he think the ground craked the pipe..
the pipe comes from my house and goes the drive way...
do I call my subdivision? or the city about this matter?
my uncle is telling me that I might have a good chance on digging up the drive way...
what should I do?
I live in Atlanta, GA
sniperm is offline   Reply With Quote
Old 10-26-2009, 09:59 PM   #2
union journeymem plumber
130 plumber's Avatar
Your best bet is to call a plumbing company to attempt to restore drain flow.Where exactly did he tried to rod out the line from?and how does he know that the sanitary sewer line is cracked?did he use a camera to inspect the sewer line?the subdivision wont touch it for the simple fact that your the only one having the problem and as far as calling the village good luck,they wont get involved unless the village main is backing up
130 plumber is offline   Reply With Quote
Old 10-26-2009, 10:01 PM   #3
Master Plumber/Mechanical
I would call a local plumber with a sewer camera and have the line looked at with a camera.
If the line is broken this will help you see and locate the break.
Bad news that the line belongs to you and the cost will be on you.
If you locate a break have the plumber get locates for utilities and have him/her get it dug up and repaired.
Hopefully the good ol' relative discount just didn't rod the line to the main sewer and that is all it is..sewer drain just needs to be rodded
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-26-2009, 11:31 PM   #4
first have them attemped to rod out the line and if that doesn't work,do as what Plumber101 recommended to have them camera out the line and hopefully your able to restore some flow to visually see the problem.Just know this if the line is holding water you wont be able to see any thing
Good luck and keep up posted on what you find
Old 10-27-2009, 12:12 AM   #5
Thanks 103P. The pipe filled with soil water completly sliped in my mind.
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
How to Unclog a Toilet
How to Unclog a Toilet by Expert Village
We have a toilet that's not flushing, or not flushing very well. What we want to find out is, is the problem in the toilet drain, or is the problem in the toilet tank delivering the water to the bowl? So what we do, we have the patented Gilbert's... Read More »
Something else that can go wrong with the toilet is the flush handle. Either the plastic guard rim or the metal arm can break; the handle can fall off, and separate where they're pressed together. The most important thing you have to know about changing... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
If you’ve noticed a reduced flushing power of your toilet over time, I have a simple recommendation for you, something for you to check. The holes on the underside of the toilet bowl often become clogged with deposits. So what you want to use is a... Read More »
Need some advice for a bunch of things. ingeborgdot Home Theater 11 02-12-2009 09:48 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 10 07-22-2008 06:41 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 01:51 PM
I need advice on a flat roof Krissy Roofing 10 12-27-2007 03:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
