Old 12-19-2012, 09:15 PM   #1
Need to resecure toilet to the flor
I took the toilet off to clear a clog and now am unable to re secure. The screw move every time I get the toilet over them HELP
loridee883 is offline   Reply With Quote
Old 12-19-2012, 09:31 PM   #2
Tileguy
Bud Cline's Avatar
That isn't very clear!
Do you mean you can't stab the toilet over the screws because they move and miss the holes, or do you mean you can't thread the nut on the bolt because the bolt twists?
Try again.
Old 12-19-2012, 10:01 PM   #3
Bolt the bolts to the flange with some nuts, do not just let them hang free. You should still have enough play in the toilet to adjust it straight.
paintdrying is offline   Reply With Quote
Old 12-20-2012, 11:30 AM   #4
Special User
My new toilet flange bolts came with little plastic dealies to keep the bolt sticking straight up while the toilet is lowered. They helped, but it was still nice to have a second person there guiding the toilet down.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-20-2012, 12:23 PM   #5
If you're just having trouble lining up the bolts with the holes in the bottom of the toilet, then slip a soda straw over each bolt. Then, get a helper to reach under and help align the straws with the holes, as you lower the toilet down. Make sure to remove the old wax ring and put a new wax ring between the toilet and flange.
Seattle2k is offline   Reply With Quote
Old 12-20-2012, 04:00 PM   #6
Roofmaster
Paintdrying has it right, but use Jam nuts, the low profile ones. Also use all Brass 5/16 Bolts Locate with a straightedge parallel to the wall, bisecting the pipe. Take the tank off and locate the bowl first, Much easier, and you should be replacing the tank bolts anyhoo. Make sure you put the plastic retainer washers with the lip up, under a stainless flat washer. That lip retains the snap on plastic cover dome.
" A lot of men build things, and a lot of things fall down "
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
