Old 04-07-2012, 10:51 AM   #1
Need to replace supply line
How would you go about replacing one of these types of supply lines. The line itself has a hole in the hose.
Justins1171 is offline   Reply With Quote
Old 04-07-2012, 11:24 AM   #2
Unscrew it and replace it. Any Lowes, Home Depot has them.
Make sure to measure the length of it first they come at least 3 differant length.
Make sure you buy the one for a sink, I believe it says basin on the lable.
You may need a basin wrench to get it off the sink.
Old 04-07-2012, 11:26 AM   #3
It didn't look like it unscrewed, that's why I was asking...
The Following User Says Thank You to Justins1171 For This Useful Post:
plummen (04-07-2012)
Old 04-07-2012, 01:00 PM   #4
Doing it myself
Alan's Avatar
It doesn't look like it unscrews to me either. Shut off the water to the house, remove the angle stop and replace it with the appropriate variety most likely 1/2" FIP or compression by 3/8 compression and get a matching supply to go with it.
I've seen some of those stops with built in supplies. Some are very old, and some are new varieties. I think to myself, why are they still making those darn things?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 10:20 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 10:54 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Is it normal to change the upper line at the meter when running new supply line? twilightcall Plumbing 3 08-08-2008 12:10 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
