Need To Repair 3/8" Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2011, 10:10 PM   #1
need to repair 3/8" gas line
accidentally cut the 3/8" copper line today while demo'ing.
how do i repair it? can i sweat a coupling on there, or is there some kind of compression fitting coupling?
i assume not safe to be sweating the pipe even though the tank is shut off?
wombosi is offline   Reply With Quote
Old 12-21-2011, 10:36 PM   #2
Rewards Points: 582
you really don't want to sweat this gas line ....they make compression cupplings.. some has used them for repair......I recommend to flare it ...because its the safest for gas using copper tubing...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
plummen (12-21-2011), VIPlumber (12-22-2011)
Old 12-22-2011, 12:14 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
Also that repair must be outside the wall not inside a closed wall.(can not be concealed)
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
suggestions for repair of 1/2" copper line -see photo mycophile Plumbing 1 11-15-2011 06:21 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
