Need Pump Setup Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2008, 11:32 AM   #1
Need pump setup help
Ive bought a liberty water pump for my darkroom sink. Im trying to set it up and I have a question. Where the pvc goes into the pump it reads 1 1/2" inlet. SO I tried to put a 1 1/2 inch pvc pipe in the hole and it is too big. Am I missing something? What do I need? Any advice appreciated. I have a check valve that I bought and also have it vented properly, now I just need advice on how to atatch the inlet and outlet PVC.
This is a pic of the pump that another photographer sent me of his set up to help with my setting it up.
pesphoto is offline   Reply With Quote
Old 07-12-2008, 02:44 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I could be wrong, but i believe DWV PVC and water PVC are different diameters. . . .
Journeyman Plumber
Old 07-12-2008, 02:45 PM   #3
Is the hole threaded? if it is double check the fitting size. It should be marded on it.
BillyD is offline   Reply With Quote
Old 07-12-2008, 10:46 PM   #4
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
DWV and Pressure pipe are the same OD (outer diameter). "Tubular" pipe, such as slip joint traps and tail pieces are made of, is a different diameter. But if the inlet is threaded, you will need an 1 1/2" male adapter to screw in and it will be a little smaller than the pipe itself, due to the threads being cut (actually molded with most plastic) into the pipe. Liberty's website shows an 1 1/2" model and a 2" model but nothing smaller.
The picture looks like 1 1/2". It also shows both an "S-trap" and a double trap, neither of which are legal or necessary. The trap at the bottom is all you need.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
sump pump issue mikehende Plumbing 15 02-15-2008 06:36 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 10:42 PM
