Old 10-03-2012, 03:51 PM   #1
Need a professional plumber's advice!
Is there a professional plumber here that can help me out with some plumbing replacement issues? Anyone?
firsttimeremode is offline   Reply With Quote
Old 10-03-2012, 05:28 PM   #2
call me E
TheEplumber's Avatar
Yep, give a detailed description. Pictures help
I'm on pst and need to finish my job first.
Sent from my iPhone using DIY Forum
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-04-2012)
Old 10-04-2012, 12:07 AM   #3
basically only one problem. Its all missing. there is piping under the trailer, but from the floor up, nothing. i need to know the basic legal layout for the different indoor plumbing designs. i have a kitchen sink, two lavatory sinks, two toilets, standup shower, bath/shower one-piece, soaker bathtub, hot water tank, and washing machine. with the washer, the two handles are there, but the pipes below them are cut off and just sitting there. i plan to use the drain holes that are already there since everything goes in the floor, i just need to know what i need to do to make it legal from the floor to the fixture. dont need special plans or designs, just whatever is legal.
Old 10-04-2012, 12:10 AM   #4
Doing it myself
Alan's Avatar
More info available here ? : Plumbing help!
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 10-04-2012, 08:09 AM   #5
Here is a fairly good diagram of what you need to do. Ignore the greywater diversion and extend the sink and tub drains right down to the sewer pipe. The rest is fairly straight forward. It took me all of 5 min to find this on the web.
danpik is offline   Reply With Quote
Old 10-04-2012, 07:04 PM   #6
good job finding layout......its not going to help him....ben sr
Old 10-04-2012, 09:08 PM   #7
Super Moderator
That one will do it----
Now I have two threads to watch----
As others have suggested----go to the library and check out a book--I have several----books are often the best source of technical information---
Old 10-05-2012, 12:24 AM   #8
it will help for the bathrooms
Old 10-05-2012, 05:31 AM   #9
Super Moderator
Kitchen sink is very much the same as the bath sink----vent could be an AAV in the kitchen if needed----AAV=air admittance valve
Also known as a 'cheater vent'----these meet code in some areas but not here----If the work will be inspected---check that out before using one.
Old 10-05-2012, 09:26 AM   #10
work wont be inspected
Old 10-06-2012, 06:34 AM   #11
Super Moderator
If there are any new houses under construction near by---ask the workers if you could look at the rough plumbing---seeing and touching the real McCoy will make your planning a lot easier----
Old 10-06-2012, 11:23 PM   #12
Good idea Mike
Comfortmaker RPJ II Ignites then shuts off? SELLC HVAC 63 11-20-2011 09:47 AM
Seeking Professional Advice seagrtj Flooring 4 03-20-2010 07:20 PM
A Gross Problem - Professional Advice Needed! DanielleM Plumbing 10 01-28-2010 05:35 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
