Need Pro Advice Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2009, 06:56 AM   #1
Rewards Points: 154
Need Pro advice toilet
I still don;t have an answer to my water leak, hopefully a pro will chime in. I noticed a few weeks ago the water running for a few seconds in my new toilet, it seems as though water was slowly leaking through the rubber flapper inside the tank, so Kohler sent me a new flapper, it did the same thing, now they want to send me a new rubber gasket that goes between the bowl and tank, but I was thinking about that? WHY? the water is not leaking from between the bowl and tank?>this makes no sense to me. I checked the seal on the tank, no debri al clear, what do you think is causing the water to leak? Thanks..Gary
turbomangt is offline   Reply With Quote
Old 09-29-2009, 08:53 AM   #2
Kohler may feel that the sealing surface could be warped or otherwise distorted and allowing the water to seep through. In cases like this, it would be hard to detect the exact location of the leak. At least they are helping with the problem.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-29-2009, 08:56 AM   #3
Rewards Points: 154
I just found out form a co worker that the rubber flapper SITS on the rubber gasket between the tank and bowl. now that makes sense. my bad
Old 09-29-2009, 09:19 AM   #4
General Contractor
Try checking the lift chain (chain going from the trip lever to the flush valve). Sometimes they are adjusted to tight and are causing a slight lifting of the flush valve (flapper).
ARI001 is offline   Reply With Quote
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
