Need A New Well Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 09:32 AM   #1
Need a new well pump?
For the last month or more we have had issues with water pressure from our dug well. The water pressure flows from strong to medium, strong to medium. While the flow rater continues to change the pump's pressure gauge "clicks" (literally makes a clicking noise) from about 55 pounds of pressure to 30/40 pounds of pressure. The weirdest issue is that sometimes the washing machine doesn't get enough water to it to fill up and it will even stop during the fill up cycle because the water doesn't flow to it. The washing machine is also farthest from the well and well tank.
We have replaced the electrical switch box at the tank to see if that would fix it. It did not.
Info on well: Its old and dug. The well pump is submerged.
What is next to fix this issue???!!! Any advice is APPRECIATED!
Apalmer is offline   Reply With Quote
Old 07-16-2012, 11:06 AM   #2
Rewards Points: 13,956
DO you have a bladder or pressure tank?
Old 07-16-2012, 01:09 PM   #3
I am pretty sure it is a pressure tank.
Old 07-16-2012, 06:05 PM   #4
Check how the pump current draw changes with the symptoms you are seeing.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
