Old 10-26-2009, 07:06 PM   #1
Extreme DIY Homeowner
Scuba_Dave's Avatar
Default Need new shower/tub mixing valve
Well 20-20 hind-sight I would have had the mixing valve replaced when I redid the shower
But it was not leaking at the time - 2004/5
A new Moen cartridge a year later stopped a small drip (2005/6 ?)
It started dripping again - off & on, now its pretty steady flow
I do have a whole house filter to prevent sediment thru the lines, installed after the last WH rusted out
I should have had the plumbing reworked & reversed the tub
The opposite wall is a closet - current plumbing is on an outside wall
Maybe in another 5 years I'll redo the bath again & have a plumber reverse the pipes/drain at that time
I have no faith that the valve has not been worn out
Almost every other fixture in the house has been replaced
As a test I shut off the HW feed to the shower, the leak stopped
So not only a water waste, but am energy loss too
The old water heater rusted out shortly after we moved in
So pretty sure rust went thru the piupes & messed up the valve
Since then both toilets are new(er), bath & kitchen faucets too
One toilet was getting sediment
So I need a new mixing valve & really don't want a low grade model from a big box store
So what's a good brand to buy?
The surround was in rough shape & leaking when we moved in
So I didn't want to let water damage continue
Bath was redone, cement board & tile
It wasn't as bad as my last house, old pic from before renovation:
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 10-27-2009, 07:53 AM   #2
Kohler, Delta, Grohe. Avoid big box cheapies, or cheap anything.
Old 10-31-2009, 08:27 PM   #3
I would think you had bad luck with that cartridge and replace it. That looks like a positemp cartridge so the vlave shouldn't be THAT old. good luck.
plumber Jim is offline   Reply With Quote
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
Hey gang, it's Don Golden here for Expert Village and the water is running and we've got to turn it off. I think we pretty much fixed our leaky little problem in here. So what we did was we took this old housing off and replaced our old leaky cartridge... Read More »
If you like putting things together with your hands, a career as a plumber might be for you. Plumbing is a highly skilled profession and one that will always be in demand. Plumbers install, maintain and repair the systems that keep our water flowing... Read More »
Hey everybody, Don Golden here with Expert Village coming to you from my shower. What are we doing in here? I'll tell you what I am doing. I've got a little leak going on and I should be a little bit of an expert on this, fixing showers, fixing leaks... Read More »
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 3 08-18-2009 12:40 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 12:11 PM
Mixing Valve replacement mediaman67 Plumbing 18 01-22-2009 10:35 PM
Need to replace shower/tub valve KenDahl Plumbing 4 10-31-2008 02:01 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 01:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
