Need To Move Toilet Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2011, 02:47 PM   #1
Rewards Points: 22
need to move toilet rough-in
Hi
I'm new to the forum and have reached out to the community seeking guidance on a washroom project which I've undertaken and messed up.
I've built walls in the basement for my washroom project where I did not considering the distant between the toilet rough-in and the wall. The distant of the pipe to the wall is approx 8". The rough-in was installed by the builder when I bought the house 13 years ago.
I though of working around the problem by installing an offset closet flange which one of the attached picture shows the distant of about 10" from the wall. However, in order for me to install the flange, I will need to cut around the drain pipe ... about 4" deep around the concrete.
I figured if I am going to rent a jack hammer and break into the concrete, I might as well look into moving the pipes. When I broke into the concrete, I discovered there is little I can do to move the pipes as there is another pipe that tee'ed into the main pipe. Here are some pictures I've captured hoping you can offer some guidance on how I can tackle this piping challenge.
Thanks in advance for any and all assistance.
Ron
need to move toilet rough-in-p1030653v2.jpg   need to move toilet rough-in-p1030654v2.jpg   need to move toilet rough-in-p1030655v2.jpg   need to move toilet rough-in-p1030656v2.jpg
rlim is offline   Reply With Quote
Old 06-01-2011, 03:23 PM   #2
Framing Contractor
Rewards Points: 80
Make the hole a little bigger, cut the smaller line and redo the whole thing. Not a whole lot more work really.
sixeightten is online now   Reply With Quote
Old 06-01-2011, 06:06 PM   #3
Plumb or Die!
Yeah, don't forget you'll need 15" minimum clearance to the side wall too. So you're stuck rearranging a bunch of stuff. Not too hard though.
plumber666 is offline   Reply With Quote
Old 06-02-2011, 12:34 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
Toilets are readily available for 10.5" rough in. If you move the 3x2 wye and the 3" 90 a couple inches, you might get it. I don't recommend offset flanges either.
Old 06-02-2011, 08:38 PM   #5
Rewards Points: 22
Thanks for the prompt response ...
Just for clarification ... the suggestion is cut below the 3x2 wye and reinstall a replacement from that point on? I'm wondering if that will still provide sufficient clearance if I don't use an offset flange.
Old 06-02-2011, 09:57 PM   #6
It will if you use a street 90.
Dougtheplumber is offline   Reply With Quote
Old 06-02-2011, 10:03 PM   #7
Plumber
Rewards Points: 348
Minimum distance from finished back wall is 10"(using a special toilet)
From the finished side wall is 15"
I don't know your pipe lengths so I can't say if you have the room, but you can also use a st. 90 into the wye. That will gain you about 1.5"
I Guess Doug types faster then me
Old 06-03-2011, 04:03 PM   #8
OMG, the 10" toilets are really expensive!!! quadruple the cost in some cases.
Bloke is offline   Reply With Quote
Old 06-03-2011, 05:42 PM   #9
Rewards Points: 22
What is a street 90? Will the folks at Home Depot know what it is if I asked for it? Also, just so that I don't mess this up again, is this where I should cut and reinstall the new wye?
Old 06-03-2011, 07:39 PM   #10
DIY staff
Rewards Points: 7,174
I agree with the others--open the floor a bit more. There appears to be another T just out of site under the concrete---that might need moving to give you the space to get that drain moved.
Old 10-15-2011, 08:18 AM   #11
Rewards Points: 2,510
Did you ever remedy this issue?
hammerlane is online now   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Where to Move this Toilet? estburke Plumbing 8 10-11-2010 12:52 AM
toilet for small space mazzonetv Plumbing 1 08-02-2009 02:59 PM
Basement toilet rough in epeterson777 Plumbing 7 01-27-2009 01:57 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
