Need To Make A Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2012, 09:51 AM   #1
Need to Make a Drain
Hello,
About 2 weeks ago I remodeled our bathroom, and one of the consequences of this remodel was that the new sink is about 6" to the right (looking at it) of the previous one. Unfortunately, neither myself nor my father-in-law were able to remove the nut that keeps the elbow (coming out of the wall) sealed to the drain. As a consequence, I am forced to use the 1-1/4" elbow.
Because of this I have a 1-1/4" PVC trap that needs to connect to the 1-1/4" sink drain. Currently satisfying this role is a 1-1/4" pipe coming out of the trap which has been caulked into a 1-1/2" elbow (using one of those size reducing washers, thread tape, and both sides of the nut caulked) that connects the straight pipe and the sink drain.
As you might imagine, this isn't working very well! The caulking holds for a few days, but eventually the water sitting in the horizontal/bottom part of the elbow works its way out.
I have tried to find non-scheduled, 1-1/4" elbows to replace the 1-1/2", but everything I find at the hardware store is schedule 40 or 80. I am about to try and find 1-1/4" ID tubing to bridge the gap...heck, I'm about ready to use garden hose if it'll work!
If anyone has any ideas or knows where I can find/make the right tools, I would really appreciate it!
Thank you for you time and help,
Ben
BenjaminE is offline   Reply With Quote
Old 06-13-2012, 11:08 AM   #2
A picture might be worth a thousand words here.
TopTechnician is offline   Reply With Quote
Old 06-13-2012, 05:40 PM   #3
Pictures and Update
When I got home with what I assumed would solve all of my problems, I was disappointed to discover two things: first, 90 degree elbows should have their vertical (if exists) component facing downward; and, second, the pipe coming from my wall comes out (see pictures).
Pictures: http://www.ohio.edu/people/be173805/.../plumbing.html
Based on the pictures, my questions are:
1) Can I replace the 1-1/4" chrome/copper pipe with a 1-1/4" pvc pipe by just sliding it into the hole in the wall, or do I need to remove that nut? If I have to remove the nut, can I cut it off and replace because it isn't budging!
2) If I can't just slide a pvc pipe in, can I just slide a chrome/copper pipe in?
3) Finally, should I use some plumber's putty around that nut if I just slide a pipe in there?
I appreciate any QUICK feedback as this is our only bathroom and we've been limping on Frankenstein drains for over a week now! Thanks again!
Ben
Old 06-13-2012, 05:49 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 826
Ben
You must get the nut off. Not really any way around it. Heat it some with a torch.
Plastic tubing and the chromed brass are the same OD so either will work once the nut is off
Old 06-13-2012, 06:12 PM   #5
Rewards Points: 14,026
I would never heat it that close to the wall.
A Dremal tool with a cut off wheel or an ossilating saw will cut the nut in half and a few taps with a chisle will knock it off.
Old 06-13-2012, 06:14 PM   #6
If I have to cut it off (worst case), is there a best practice for doing so? What type of nut would I be looking for to replace it?
Thanks,
Ben
Old 06-13-2012, 06:16 PM   #7
Thanks, Joe, I just hit submit when your post showed up! Any advice on replacing? Do I need a plastic washer/reducer when I do?
Old 06-13-2012, 07:16 PM   #8
Plumber
Rewards Points: 826
Whether you heat it or cut it. Don't damage the male threads.
it wont do any good to replace the nut because you're to far to the side of the tailpiece to fit the trap. You'll have to use a 45 or 22 to redirect and line up to the tailpiece.
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (06-14-2012)
Old 06-14-2012, 06:32 AM   #9
I was able to get the nut off very easily with a little bit of heat from the heat gun. I had a few different pieces lying around and I was able to put the drain in the attachment together. I haven't pasted it together, so it won't be much to change...but hopefully it is good enough.
Ben
Old 06-14-2012, 08:54 AM   #10
Plumber
Rewards Points: 826
Or use an illegal flex tailpiece like in your picture...
Old 06-14-2012, 09:28 AM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Ben
Get that flex line off of there, and use a real fitting at the wall.
I also don't know what you mean by "pasted it together" but don't do that, because it's not necessary.
Journeyman Plumber
Old 06-14-2012, 10:00 AM   #12
Bill Kearney
Rewards Points: 1,174
Yeah, flex line get nasty, quick. You're going to see that sink getting clogged up a lot sooner than it would with proper connections.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
VIPlumber (06-15-2012)
Old 06-14-2012, 10:23 AM   #13
Makes sense about the flex pipe being a crud collector. So I have no doubt that using an angle out of the wall to place the trap directly under the sink is the best way to go, but where do I find 1-1/4" OD fittings? I've looked at all of our local hardware stores and they don't carry crap for 1-1/4" OD fittings except those junky size reducing washers they have so you can connect 1-1/4" OD inside of a 1-1/2" OD fitting.
Do they make 1-1/2" to 1-1/4" adapters so that I could have a bit of 1-1/4" coming out of the wall and the rest being a 1-1/2" system?
By the way, thank you for all you've helped so far--I really appreciate that I can see the light at the end!
Old 06-14-2012, 08:05 PM   #14
Doing it myself
Alan's Avatar
You may need to thread an adapter onto the adapter that's already there. . . .
Around here we are only allowed 1 slip joint on the outlet of a trap, but they do make 45* slip joint fittings. I'd rather use one of those than that funky flex garbage.
Journeyman Plumber
Old 06-14-2012, 09:17 PM   #15
Gotcha! I'm gonna have a more thorough look around some of the smaller hardware stores and see what I can find.
On a separate note, any reason why there is a slight trickle on the threads immediately under the sink (where the large nut and rubber washer are)? It's really slight right now, but I worry it'll only get worse over time.
Ben
Porcelain Install Job on Basement Slab, How to make Floor Drain Flush... Firehawk734 Flooring 13 11-17-2011 09:30 PM
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
