Need A Long Feed Pipe To Fridge. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2010, 12:03 PM   #1
Need a long feed pipe to fridge.
How Long Can A Water Feed Pipe To A Fridge Be
Canadaguy is offline   Reply With Quote
Old 09-15-2010, 12:14 PM   #2
I think the code in my area is 10 feet, but you can use 1/4" soft copper and make it as long as you want. I'd use one piece only, don't splice it in the middle or anything like that
the_man is offline   Reply With Quote
Old 09-16-2010, 05:43 AM   #3
Rewards Points: 1,216
Yes and you should install a regular valve and reduce it to 1/4 " don't use them cheap saddle valves they leak and cause problems.
COLDIRON is offline   Reply With Quote
Old 09-16-2010, 06:31 AM   #4
Chicago, IL
Michael Thomas's Avatar
Also, many AHJs in my area prohibit the use of the flexible plastic supply lines sold for this purpose.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
