Need Irregular Pvc Elbow - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 02:23 PM   #1
Need irregular pvc elbow
I'm installing a composting toilet in a cabin that doesn't have a septic tank. The toilet requires a roof vent to carry away the gases formed during the composting process. A rough diagram of the installation is below:
The cabin is an "A-Frame" with 16/12 pitch roof. I intend to run the pipe up the wall until it reaches the roof, then diagonally along the rafters to the ridge and vent it out there. The vent pipe is 2" PVC.
The manufacturer includes two 45 degree elbows for just such a setup. My problem is that I have a cathedral ceiling with a steep pitch, so I would want the elbow to match the angle of the roof so I can bury it behind the sheetrock. A 45 degree elbow will not work for me.
The angle of the roof is 53 degrees off horisontal (37 off vertical). I am looking for some sort of swivel elbow product to junction the vertical pipe segment and the one that will run along the roof rafters at an arbitrary angle.
Can anyone suggest such a product?
Regards,
Huai
huai is offline   Reply With Quote
Old 08-05-2010, 02:26 PM   #2
the Musigician
DangerMouse's Avatar
Can't you just use 2 45's at each end to make them any angle you need? Po)
DM
Old 08-05-2010, 02:28 PM   #3
the Musigician
I also saw a 60 at the store yesterday....that might be close?
DM
Old 08-05-2010, 03:11 PM   #4
Owner
LateralConcepts's Avatar
Use more than 1 fitting and roll them to accommodate the angle
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-05-2010, 03:14 PM   #5
That's an idea - have to contact the manufacturer to see if the exhaust fan is powerful enough to handle this.
Old 08-05-2010, 03:23 PM   #6
Owner
Use one regular fitting (22 or 45) and another street 22 or 45. One side of the "street" fitting is made to fit inside the regular one (instead of using a stub of pipe). They can then be rolled (twisted) to change the angles. Dry fit first to save fittings.
Lateral
(208) 818-8241
Old 08-05-2010, 04:52 PM   #7
KemoSabe
loneframer's Avatar
I've seen PVC heated and bent to off angles in the past. Consistant heating is paramount to a neat bend.
loneframer is offline   Reply With Quote
Old 08-06-2010, 12:44 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 826
use a "swing joint" - one 90 elbow at a right angle to the roof rafters (verticle to horizontal), short nipple and another 90 pointed up the pitch of your roof. Repeat the process at the ridge. Like the center pipe layout in the image
Old 08-06-2010, 11:17 AM   #9
WDR
elbow
look at mcmaster car they have what you need. item# 4747T11
www.mcmaster.com
WDR is offline   Reply With Quote
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 03:22 PM
off angle drywall hanging/finishing? ponch37300 Drywall & Plaster 2 07-14-2008 06:13 AM
Tight drilling angle fw2007 Electrical 8 05-31-2008 09:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 04:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
