Need Instructions To Install A Fiberglass Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2010, 06:41 AM   #1
Need instructions to install a fiberglass bathtub
where can I get exact instructions of how to lay in a bed of thin-set under the fiberglass tub? Thank you,Rosie
larryandrosie is offline   Reply With Quote
Old 04-05-2010, 09:32 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I took the liberty of removing your question from the other thread and created one of your own to expedite a speedy reply for you. The doctors will be in shortly to assist you.
DM
Old 04-05-2010, 11:50 AM   #3
I use pre-mix mortar in a bucket. Measure how much space you will be filling in from the floor to the tub bottom and add 1/2". Make sure you don't place any under the tub supports that are made to sit on the floor. Place a piece of plastic on the floor before pouring out the mortar. This prevents the wood floor from moisture damage and sucking the moisture out of the mortar before it sets.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-05-2010, 11:54 AM   #4
the Musigician
See Rosie? I told you so! Thanks MD!
(get it? doctors? MD? hehehehehe Man, I kill me sometimes)
DM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Exposed fiberglass insulation in partially-finished basement skysurf Building & Construction 1 04-11-2009 09:40 AM
Call for help with fiberglass tub install yohan Plumbing 3 05-24-2008 04:23 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
