Old 04-24-2006, 11:09 PM   #1
Need to install a water pressure regulator
Hi I need to install a water pressure regulator.
Our house never has had one.Where the main
line comes in by the garage there is really not a
section where I can just cut the pipe and install
one.The pipe is comming out of the concrete
footing and about three inches up is a hose bib
and then a couple inches from that is another
T going to some thing else and then another T
going some where else.
I am having to spend money here and there on the
house so I am trying to do every thing myself.
It looks like where the pipe is comming to the house from
the meter is probly part way in the slab footing.
Just along the edge of the footing.
I am wondering if I could break away a little bit of
the footing and install the regulator there.
I have an air chisel that would break away the
concrete.Would this be a good way to go about
this job?
Thank's Doug
Doug Crf is offline   Reply With Quote
Old 04-25-2006, 01:15 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Isn't there anywhere that you can install it in the main supply line near the meter without cutting into any concrete?
A Pressure Reducing Valve needs to be adjusted from time to time, so it really needs to be accessible, too.
A PRV also creates a "closed" system, so you're probably going to have to install an expansion tank at your water heater also, or normal thermal expansion from the heater will cause the T&P valve of the heater to leak.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-20-2009, 02:23 PM   #3
how do i change the water pressure regulator?
martindb is offline   Reply With Quote
More On This Topic
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
How to Cut Copper Pipes
How to Cut Copper Pipes by Expert Village
Hey good people, I'm back with Expert Village and I'm Don Golden. We are talking about copper pipes and how to sweat them, cut them, and put them together so they can hold water. I have got a length of pipe right here and pipes are pretty standard. You... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Ok. We're outside the house now. We're going to talk about where we tie these to the existing sewer line. And, you remember that we had Arizona Blue State come out and mark the ground on the street to give us an idea of where this sewer line is. Where it... Read More »
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
