Need A Hole In My Copper Sink...HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2013, 03:49 PM   #1
Rewards Points: 31
Need a Hole in my copper sink...HELP
I am installing a new counter-top and we have purchased a 14 gauge copper sink. This sink will not be under-hung but will just be top mounted. There are no holes in the sink for a faucet and there needs to be one since there is not enough room on the counter top to mount the faucet behind the sink. First question is are there any suggestions on where I might be able to get a hole punched in the metal or drilled. Second question is if I have to do it myself then what is the standard size hole for a single hole sink and what do you think I should use to drill the hole. Gonna be a huge bit if I have to drill it.
warrior58d is offline   Reply With Quote
Old 04-07-2013, 04:42 PM   #2
Rewards Points: 582
lets see a picture of the sink BEFORE you go any farther....what style and make of faucet are you thinking...ben sr
Old 04-07-2013, 04:47 PM   #3
Rewards Points: 14,290
No one knows what faucet you have so no way to know what size hole you need. Just going to have to measure what you have.
Most often you just use a hole saw.
Old 04-07-2013, 05:29 PM   #4
This is the only tool I would use to make those holes. You don't want to damage your sink. I have a set of hole punches made by Greenlee. They make a nice clean hole in any metal surface and are very simple to use. Electricians use them to make extra holes in panels. you should be able to rent a set at any fair sized tool rental store.
The Hammer is offline   Reply With Quote
The Following 4 Users Say Thank You to The Hammer For This Useful Post:
ben's plumbing (04-07-2013), COLDIRON (04-08-2013), oh'mike (04-07-2013), TheEplumber (04-07-2013)
Old 04-07-2013, 05:48 PM   #5
Rewards Points: 31
Here is the sink, 14 gauge copper and the faucet is a Delta faucet. I would assume that most sinks that have holes already drilled are just a standard size. We are not planning on using the soap dispenser and this faucet is good for a one hole set up.
Old 04-07-2013, 05:59 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Looks like an undermount sink to me.
Journeyman Plumber
Old 04-07-2013, 06:00 PM   #7
Rewards Points: 636
i also agree with alan but if you want to know
most sinks have 1 3/8 hole size
i agree with a hole punch being the best
2nd would be a step bit
3rd a whole saw but be careful they wobble when cutting metal and make a not so perfect hole
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-07-2013, 06:34 PM   #8
Rewards Points: 31
In the mounting instructions it has both under and top mount directions. We are going with 180 FX so have to top mount it.
Old 04-07-2013, 06:51 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 904
The knock out tool The Hammer pictured above is what I use on stainless steel sinks. Should work great on yours- 1 3/8" hole
The Following User Says Thank You to TheEplumber For This Useful Post:
warrior58d (04-07-2013)
Old 04-07-2013, 06:54 PM   #10
Doing it myself
Alan's Avatar
Does it have a rail underneath for mounting clips?
Sure you can mount an undermount on top of the countertop, but it isn't designed to be installed that way and usually looks like poopie cakes.
Journeyman Plumber
Old 04-07-2013, 07:04 PM   #11
Rewards Points: 582
yep most sinks have 1 3/8 opening...but I would measure the base of faucet and the space you have on sink rim....1 3/8 may be alittle to big for sink..so see what is the smallest hole for faucet...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 04-07-2013, 07:36 PM   #12
Rewards Points: 31
1 3/8 will easily fit. It's a 2 in rim all the way around and I plan on bringing it it a bit between the bowls. should be no problem. Now I just need to find someone with a knockout hole punch cause the local big box store wants 258 for a kit and don't have individuals. Already sent email to some plumbers so we will see what we see. Thanks to everyone for all the help.
John
Old 04-07-2013, 07:41 PM   #13
Rewards Points: 31
Poopie cakes it is then.....the wife wanted "this" copper sink and I told her that it should be undermounted but we can't afford stone so she got the idea somewhere to top mount so that is what's gonna happen. It's her kitchen and as long as mommas happy I'm happy. I do appreciate all the help though. Thanks
Old 04-07-2013, 07:43 PM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 996
Not gonna work this is clearly an under-mount sink, has absolutely no rim support or clip tracks to act as a top mount, and if you cut 2 holes into it youll just weaken it more. the minute you start putting weight on it the tips will pop up and start to buckle. looks like a very nice sink don't kill it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-07-2013, 07:54 PM   #15
Master Plumber
Javiles's Avatar
Rewards Points: 996
Note the area required for faucet deck this is a copper finish sink top mount
Need a Hole in my copper sink...HELP-schock-houzer_granite_kitchen_sinks-ex-madison-n-200-copper-s3.jpg
The Following User Says Thank You to Javiles For This Useful Post:
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Copper Kitchen Sink bareshiyth Remodeling 4 01-25-2012 10:30 AM
Angle valve on 1/2" copper tube for bathroom sink Bigb142 Plumbing 4 12-10-2011 08:24 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 10:09 PM
