Need Help With Well! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2010, 07:58 PM   #1
Need Help with Well!
I have a drilled well with a submersible pump. Last week I noticed that I am getting running water flowing back down into my well. It has been doing this for a week now, and it never stops. I am not losing any pressure from my pressure tank, that would be sending the water back. Water supply in the house is normal, with no problems. Any Ideas???? Thanks for the help guys!!!
litenin20 is offline   Reply With Quote
Old 03-24-2010, 08:28 PM   #2
Civil Engineer
Rewards Points: 4,772
Perhaps you could be a bit more specific. From your description, it sounds like water is running out of your house and back into the well, which sounds like your backflow preventer has failed. However, possibly you meant that surface water outside your house was flowing into the well?
If the backflow preventer has failed, and water is running back into the pump from the house, the pressure in the house would have to drop, perhaps slowly. But you stated that the pressure in the house does not drop, which would be impossible if water were actually running from your house to the pump.
Old 03-24-2010, 08:33 PM   #3
It is running out of the pipe that goes to my house, back into the well. I have sat infront of the pressure tank, and have not seen the pressure needle move. unless water is being used somewhere in the house. with no faucets open, pressure tank gauge doesn't budge. I don't get this either.....
Old 03-24-2010, 08:43 PM   #4
Civil Engineer
I assume you know that the water is running from the sound it makes. Assuming this is correct, you have a stuck water pressure gage. It is not possible to be losing water and not losing pressure. In the immortal words of Sherlock Holmes, when you have eliminated the impossible, then whatever remains, no matter how unlikely, must be true. So I conclude that if the water in fact is running back into the pump, you have broken backflow preventer, and a stuck pressure gage.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
litenin20 (03-24-2010)
