Need Help Understanding Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2013, 02:01 PM   #1
Need help understanding old cistern
I have a 1904 house that I've been in for a year and don't know the purpose of what I would describe as a well. As you'll see in the schematic and pictures, there are 3 pipes that can discharge into the well. One is aimed straight into the basement--all the pipes in the basement are capped. The second one may have been connected to a downspout at one point. It seems to aim at the corner of the foundation, one picture shows a hole near the corner of the foundation. The largest pipe (parallel to house) goes to places unknown but could theoretically intersect the current sewer pipe.
Questions
1. What is this and is it still necessary?
2. Does anything need to be done with water inside well?
3. Do I need to keep it accessible or can it be sealed?
4. Could I cap the hole near the corner of the foundation?
5. What are the chances that I'll need to someday excavate to remedy a problem (I'm hoping to make the side yard a garden)
See next post for two additional questions
Need help understanding well-dsc01781.jpg   Need help understanding well-dsc01783.jpg   Need help understanding well-dsc01777.jpg   Need help understanding well-dsc01779.jpg
tabatt07 is offline   Reply With Quote
Old 04-21-2013, 02:04 PM   #2
How would one repair the concrete at ground level (e.g. how would you get the concrete to stick without falling into the well)?
I've also got a cannon ball looking thing in the front yard. I dug around it and it's a cast iron cap that could be pulled upwards. Some dirt fell in and I heard it hit water. Does that tie into the well? Do I need to keep the cap? Could I replace it with a PVC plug?
Need help understanding well-dsc01786.jpg   Need help understanding well-dsc01787.jpg
Old 04-21-2013, 02:42 PM   #3
Rewards Points: 13,270
Looks more like an old cistern system.
http://www.bing.com/images/search?q=...ectedIndex=110
Old 04-21-2013, 04:00 PM   #4
Roofmaster
Rewards Points: 2,172
Looks like a good way to get Cholera to me.
Old 04-21-2013, 04:17 PM   #5
joed's Avatar
Rewards Points: 11,990
Stick a hose down some of those holes and run water. You will know if they connect to the well. I think it is more of a cistern then a well that was setup to collect water from the roof downspouts.
Old 04-22-2013, 06:11 AM   #6
I agree that it appears to be a cistern. I still have some investigating to do before I figure out my next steps. For posterity, here are two links that added to my understanding.
The Old-House Journal article from the 1980s
http://tinyurl.com/csfy5pp
Angie's List article from 2011
http://www.angieslist.com/articles/c...d-resource.htm
Old 04-22-2013, 11:53 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Lots of older houses had cisterns dug as a way to dispose of water. Drain water, rain water, floor drains, downspouts all could have been piped into a cistern. Do you need it? We can't tell you. If you eliminate it where will your waste water go? On top of the ground? If your basementdrains lead to it, where will you go with the water if it is eliminated? The ball shaped item is likely a vent. It should probably stay a vent and be raised above ground to work. Should you keep it accessible? Probably. If it clogs with mud or leaves, you'd want to be able to flush it.
Understanding this wiring schematic 3500lt Electrical 39 02-05-2010 02:28 PM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 10:15 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Understanding live vs dead loading WFO Building & Construction 10 11-07-2008 12:06 PM
Noob needs help understanding sub-panels, please! YerDugliness Electrical 14 09-14-2008 11:35 PM
