Old 01-30-2011, 03:11 PM   #1
Need Help With Towel Rack
Hi, I am new to the forum and I cannot find the right towel rack to fit in the built in moldings that are part of the house. Below is a picture of the moldings, the space between them is 23in. Any help would be appreciated
Snf1694
snf1694 is offline   Reply With Quote
Old 01-30-2011, 03:47 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I believe those brackets slide straight up. If not, look for a set screw. Of course, they could be glued on too.....
Then take one to your local hardware store and ask them for the chromed (square) steel rod that goes into the square openings. If they're permanent, the fix will be different.
Measure length before disassembly.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-30-2011, 10:14 PM   #3
You might be able to have a hardware store custom cut you something also.
alongston is offline   Reply With Quote
Old 01-30-2011, 10:47 PM   #4
Homerepairguy's Avatar
Snf1694
When you say "I cannot find the right towel rack to fit in the built in moldings that are part of the house" do you mean that there is no apparent way to remove the towel bar holders shown in your photo to allow installing a towel bar? Or do you mean that you are able to remove the bar holders but cannot find a bar to fit the openings in the holders?
HRG
Homerepairguy is offline   Reply With Quote
Tags
bathroom, pole, rack, towel
How to fix Ceramic towel rack that got knocked out of the wall? There are 2 square holes now on each side to the wall? nicki3174 Kitchen & Bath Remodeling 8 11-21-2011 10:08 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 09:20 PM
How do I repair a broken towel rack that was attached to the tile? meganprncss General Discussion 2 05-03-2009 10:40 AM
Removing Towel Rack to paint bathroom bigbearok Painting 3 02-12-2009 06:40 PM
Removing towel rack from tile Cossack Remodeling 6 01-17-2009 09:40 AM
