Old 02-07-2013, 08:54 PM   #1
Need help with toilet flange
Im replacing a toilet and when I took the old one off the flange came with it. The bolts were completely corroded. It appears the flange wasnt even screwed down, there is no material around the pipe for a flange to be screwed into, I really have no idea how it was connected. So how am I going to get a new flange on there when there is a big gap between the pipe on the floor?
Arsinek is offline   Reply With Quote
Old 02-07-2013, 08:56 PM   #2
It looks like you could just glue a new PVC type flange with a metal ring.
RFWWorker is offline   Reply With Quote
Old 02-07-2013, 08:58 PM   #3
MarginallyQualified
Originally Posted by Arsinek View Post
So how am I going to get a new flange on there...
Take this picture with you when you go to the store.
Buy a flange. Take it home. Compare it's width with the gap.
Old 02-07-2013, 09:08 PM   #4
So there might be a flange wide enough to make it over that gap, then I could drill into the concrete?
Old 02-07-2013, 09:17 PM   #5
call me E
TheEplumber's Avatar
Read Oh' Mike's comment on this thread-
Toilet Flange Disaster. Please Help
Old 02-07-2013, 09:18 PM   #6
Is it a slab foundation?
Old 02-08-2013, 07:22 PM   #7
yes....................
Old 02-08-2013, 07:26 PM   #8
some good info there.
Old 02-08-2013, 07:39 PM   #9
Roofmaster
Look at the bottom of your toilet. I bet the flange went with the toilet. It looks like you could clean the pipe up and just glue in a new flange to me. Use a Souix Chief with a stainless flange and PVC horn.
" A lot of men build things, and a lot of things fall down "
The Following User Says Thank You to jagans For This Useful Post:
TarheelTerp (02-08-2013)
Old 02-08-2013, 07:52 PM   #10
Not exactly the one I was looking for but may work. You maybe able to find a flage that will work. Drilling and anchor into a slab is fairly easy.
paintdrying is offline   Reply With Quote
Old 02-08-2013, 08:42 PM   #11
http://www.bing.com/images/search?q=...electedIndex=3
And one of these.
http://www.bing.com/images/search?q=...lectedIndex=30
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
