Need Help With Sink Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2010, 01:16 PM   #16
Rewards Points: 1,002
Originally Posted by profenx View Post
It could be plugged in the few months I have used the sink ... but I find it unlikely. I did use baking soda and vinegar. set it out for an hour and flushed with really hot water. Then again, it won't cure every clog. For sure there is no hair.
Exactly what is baking soda plus vinegar supposed to do except react with each other and form CO*2 and H*20 ? I am unaware of any cleaning capabilities when those substances are combined. As a matter of fact, I believe that the free Na that results from this reaction could result in the formation of a salt, which could encrust upon your pipes.
Anti-wingnut is offline   Reply With Quote
Old 05-26-2010, 06:46 PM   #17
Leak Master
Shhhh..... some plumber is gonna get some work outta this.
O'Leaky is offline   Reply With Quote
Old 05-26-2010, 06:59 PM   #18
so whats down stream of the sink?
The older I get the better I was
Old 07-31-2010, 02:55 PM   #19
Send a message via AIM to profenx
You can form salt from the mixing of vinegar and baking soda? it produces a gas. Besides, I flush it with really hot water for long period of time. Shouldn't cause any damage to good piping from the one or two times. It cleared my bathroom drain
So ... those who said it was plugged was right. Somehow the pipe was plugged down the line. I called a plumber ... who screwed it up and backed up all sinks in the house and said he would have to charge me ot to get it fixed cuz it was after 7. This was roto rooter. Excuse me? he backs up all my sinks and didn't fix the problem and then wants money to fix the other problems he created? The cabling for 3 hours ended up damaging my CI pipe and now I have thousands in cost to repair the pipe under a slab.
I'm working with another plumber for this. I'm trying to get them to help me out with financing. I can't believe what a nightmare this year has been. I had everything go wrong in this house. Apparently multiple plumbers have stated that this problem is pretty bad and one said it's the worse he has seen in 5 years. Also agreed that no one could have known about this problem except previous owners.
Anyhow ... i need to take on a 2nd job now
thanks for the advice ppl.
profenx is offline   Reply With Quote
Old 08-01-2010, 05:35 PM   #20
Rewards Points: 150
Sink Problem
Here's my two cents:
AAVS go bad, water comming out of it is not a good sign (it needs to be replaced)
The use of the garbage disposal forcing water out of the AAV indicates it can't get down the drain.
To me I would look for a partial stoppage in the line beyone the sink where the lines come together, you need to run a snake a lot farther down the line, a plunger is not going to work.
braindead is offline   Reply With Quote
The Following User Says Thank You to braindead For This Useful Post:
plummen (08-01-2010)
Kitchen, sink, plumbing ?'s Canada 83trekker Plumbing 3 01-10-2010 02:31 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
Need Help Plumbing A Utility Sink... drummereef Plumbing 17 07-29-2008 04:16 PM
