Old 05-20-2012, 12:40 PM   #1
Need help on running gas line to detached garage
I am running gas and electric to my detached garage from my house. The trench is dug and is double the required depth per IBC. I borrowed a Hilti hammer drill from a friend and have the hole for the electric already drilled. My question for this project is; where should the gas line go through the foundation in my house? I am using plastic gas line so it is correct for underground use. Should it go through above grade with iron and then connect to the plastic? Thanks
Graham
gjones is offline   Reply With Quote
Old 05-20-2012, 01:34 PM   #2
Framing Contractor
Graham
Ask your building department that question. They will know. It's your area that counts to give you that information.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-22-2012, 07:30 AM   #3
Most areas allow live in homeowners to do their own electrical work, but it still needs to be inspected. They generally frown on homeowners doing gas lines. It MUST be done correctly, or the risk is death/injury.
running power to detached garage Roundeye Electrical 10 11-30-2011 10:05 AM
Wiring a detached garage from another detached garage? bhawghead Electrical 7 05-25-2011 01:54 AM
Running new service to detached garge italie Electrical 2 04-22-2011 02:46 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing 3 11-06-2009 10:07 AM
