Need help replacing shower diverter valve
Hi all, newbie here, help appreciated....
In my shower, when the valve is set to "shower," there's still a lot of water coming out of the tub faucet. After doing some reading, it sounds like I need to replace the diverter valve. Problem is, I can't get to it. The valve lever (not sure if that's the right term) has a screw on the end of it, and I thought when I took out the screw it would just pop out, but no luck. I have pulled as hard as I can and turned it both ways, and it won't come off. Is there some trick to this? There are no other visible screws, except one on the face plate against the wall, and that just frees up the face plate and doesn't affect the lever. I have a couple of pictures in case that helps. Thanks!
