Old 05-26-2010, 07:26 PM   #1
Need help removing Delta bathroom faucet
I've got an 8 y.o. Delta faucet in my bathroom. I can't seem to loosen the Allen screw in the hot faucet. Can someone help me?
Neither faucet has ever been removed before. My 3/32 Allen wrench seemed a tad too loose, but my 7/64 Allen wrench is clearly too big. I called Delta, which told me that those allen screws took either a 3/32 or 1/8 Allen wrench.
On the cold tap, I was able to get the wrench in, and it seemed like it was in very well, but it slipped out when I tried to turn it.
Of course, I'm afraid of stripping the head on these screws. But I'm totally stymied!
What's the secret to success here?
Mr_allthumbs is offline   Reply With Quote
Old 05-27-2010, 01:03 AM   #2
Doing it myself
Alan's Avatar
Sometimes you just can't get them out.
2 options : If you want to try and save the faucet, you can try drilling out the allen screw or using a screw extractor kit or something similar....
Otherwise you can just replace it. I hate those little screws sometimes
Journeyman Plumber
Old 05-27-2010, 07:18 AM   #3
Man of many hats
wrangler's Avatar
Have you tried a different 3/32 wrench yet? Sometimes the end will get a bit rounded making it slip. A grinder or fine metal file can also be used to remove the rounded tip if needed. Otherwise I might even try a metric in case someone used a metric set screw because they lost the original.
Man of many hats
wrangler is offline   Reply With Quote
Old 05-27-2010, 08:00 AM   #4
Yeah, one of the first things that occurred to me. I tried a metric--2.5 is the closest "next-biggest". Too big.
Old 06-01-2010, 03:11 PM   #5
ALLEN (et al):
Do you think it would help if I put some heat (torch) on the screw?
Old 06-01-2010, 04:18 PM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Have you tried inserting the Allen wrench and giving it a few taps with a hammer to try to break loose any calcium deposit buildup in the threads, or soaking it a bit in vinegar to dissolve the calcium?
Or, if you can get one to bite good, gripping the Allen wrench with channel-lock pliers for torque?
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-01-2010, 05:50 PM   #7
Good idea, I'll try it, thanks.
Tags
allen wrench, bathroom faucet
New Delta faucet drips KE2KB Plumbing 10 02-28-2012 10:34 AM
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 26 02-18-2012 10:23 AM
Bathroom Faucet rrizz Plumbing 8 04-12-2010 08:32 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 09:33 AM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 10:55 PM
