-   -   Need help removing Delta bathroom faucet (http://www.diychatroom.com/f7/need-help-removing-delta-bathroom-faucet-72147/)
Mr_allthumbs 05-26-2010 06:26 PM
I've got an 8 y.o. Delta faucet in my bathroom. I can't seem to loosen the Allen screw in the hot faucet. Can someone help me?
Neither faucet has ever been removed before. My 3/32 Allen wrench seemed a tad too loose, but my 7/64 Allen wrench is clearly too big. I called Delta, which told me that those allen screws took either a 3/32 or 1/8 Allen wrench.
On the cold tap, I was able to get the wrench in, and it seemed like it was in very well, but it slipped out when I tried to turn it.
Of course, I'm afraid of stripping the head on these screws. But I'm totally stymied!
What's the secret to success here?
Alan 05-27-2010 12:03 AM
Sometimes you just can't get them out.
2 options : If you want to try and save the faucet, you can try drilling out the allen screw or using a screw extractor kit or something similar....
Otherwise you can just replace it. I hate those little screws sometimes :(
wrangler 05-27-2010 06:18 AM
Have you tried a different 3/32 wrench yet? Sometimes the end will get a bit rounded making it slip. A grinder or fine metal file can also be used to remove the rounded tip if needed. Otherwise I might even try a metric in case someone used a metric set screw because they lost the original.
Mr_allthumbs 05-27-2010 07:00 AM
Metric Allen wrench didn'twork
Yeah, one of the first things that occurred to me. I tried a metric--2.5 is the closest "next-biggest". Too big.
Mr_allthumbs 06-01-2010 02:11 PM
Extracting an allen screw
ALLEN (et al):
Do you think it would help if I put some heat (torch) on the screw?
Mike Swearingen 06-01-2010 03:18 PM
Have you tried inserting the Allen wrench and giving it a few taps with a hammer to try to break loose any calcium deposit buildup in the threads, or soaking it a bit in vinegar to dissolve the calcium?
Or, if you can get one to bite good, gripping the Allen wrench with channel-lock pliers for torque?
Mike
Mr_allthumbs 06-01-2010 04:50 PM
Vinegar to break up calcium deposits
Good idea, I'll try it, thanks.
