Need Help Re-routing Main Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2011, 01:31 AM   #1
need help re-routing main stack
Was wondering what some plumber would suggest to reroute my main stack vent.
Looks like when the dormer was built, there didn't figure to make enough room for the stack too. So they half assed it and it comes out of the wall.
I would like to set it up so it runs up the dormer wall and out of the dormer's roof.
wall construction is 2x4. 4" pipe will not fit.
was thinking like Y ing from the hub into two 3" pipes and running that up the wall. Seems I can not find that type of Y though.
Toilet is roughed in @ 12"(can not move it forward due to joyce.) I bump out the wall behind the toliet to a 2x6, run the 4" all the way up, and goto a 10" toilet. If I went this route, I would use two 45* turns to move the stack out of the wall.
thanks,
Brian
need help re-routing main stack-mainstack.jpg   need help re-routing main stack-stackvent.jpg
beamar is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Main vent stack moving / resizing / removing (///AG) SFX Group Plumbing 11 11-16-2010 07:47 AM
Max run for 3" Toilet run to main stack brokenhammer Plumbing 2 01-27-2010 07:52 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
