Old 11-01-2005, 12:59 PM   #1
25 days: counting down
Need help with pvc question
Good morning.
I'd like to know from some of you folks that use pvc frequently, what size pvc piping I could use to get a 14' length that would be sturdy enough to put 2' into the ground, and have it stand straight up and be sturdy, not bend over. It's for a christmas project.
ballhog24 is offline   Reply With Quote
Old 11-01-2005, 07:48 PM   #2
Contractor
You want at least 1/4 of the length in the ground, 2' is OK for a 6' fence post. 4" sched. 40 would be the minimum, sched. 80 would be better. Both come in 20' lengths and I'd stick about 4' in the ground to be on the safe side.
You also don't mention what you are doing with this pole, that could change the parameters.
Teetorbilt is offline   Reply With Quote
Old 11-02-2005, 09:58 AM   #3
Originally Posted by ballhog24
Good morning.
What're you doing, stringing lights from the top to the ground?
2" Schedule 80 PVC is pretty stiff and manageable by hand You can get it in 20' lengths. A good answer to your
question really requires more info about the the kind of load (weight and cross-section) you're wanting to put on the pipe. A 2' bury depth isn't going to hold much on a 12' reveal. Give us some more details about what you want to hang on the pipe.
pipeguy is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Outdoor Slate Question (with pictures) kabbak Flooring 2 07-05-2006 04:02 PM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 09:04 AM
