Need Help Plumbing A Utility Sink... - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2008, 03:06 PM   #16
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
I think it will work fine. Just remember, you don't need a trap on the laundry sink, the washer standpipe should already be trapped under the floor. If not, you would have smelled sewer gas by now.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 07-29-2008, 03:10 PM   #17
Ok, great. Yeah, I can see water at the bottom of the washer standpipe so I'm assuming it has a trap already.
By adding an additional trap to the sink, would it potentially be a violation? Is there such think as double trapping?
drummereef is offline   Reply With Quote
Old 07-29-2008, 03:16 PM   #18
mstplumber's Avatar
Rewards Points: 150
It's against code for anything to be double trapped and it serves no purpose to do so. There purpose of a trap is to prevent sewer gas from escaping the system and you already have one. Adding another one just creates more joints to leak and wastes money. Just use a trap adapter and tailpiece to connect to an 1 1/2" drain pipe.
Mstplumber
utility sink pump furiousstyles Plumbing 4 11-06-2009 03:52 PM
Installing a utility sink BNPadgett Plumbing 1 05-03-2008 09:49 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
