Need Help Plumbing A Utility Sink...
Looking to install a utility sink in an unfinished area of our basement. I'd like to install the sink between the clothes dryer and the master bath shower/toilet drain. All existing plumbing is PVC.
My question is... Where would be the best place for the sink to drain and vent? Is it against code to plumb the drain into the washing machine standpipe? Any advice would be great. Thanks! Pic of washing machine standpipe, sink placement, and master bath shower/toilet drain. http://i202.photobucket.com/albums/a.../Pictures3.jpg Pic of traps from the master bath drain. http://i202.photobucket.com/albums/a...ictures005.jpg Pic of master bath shower/toilet drain (left) and master bath sink drain (right) http://i202.photobucket.com/albums/a...ictures004.jpg Pic of washer/dryer, standpipe drain, and sump pit. http://i202.photobucket.com/albums/a...ictures001.jpg |
I'd just tap into that 3" stack to the right for the drain. It would not be hard to cut in a wye fitting above the floor. As long as the 1-1/2" trap is no more than 6' from the stack, you can probably get away with wet venting it.
Alteration of the washer drain pipe would be a no-no! If you get it all piped and determine that it isn't draining/venting as well as it could be, an air admittance vent on a vertical run of pipe could easily be cut in and secured to the wall. |
You certainly can cut the waste into the 3" stack. It wouldn't pass an inspection but you can probably get away without venting it. An AAV would probably be the best way. Is their a vent down there that you could pick up though?
It is against code to connect to the washing machine standpipe, but it will work fine if you use a wye on the standpipe. You would not need to vent it at all if you use the standpipe.
If you want to meet code here's how: Cut a 4 x 2 sanitary tee into the waste stack about 1' above the floor, run a 2" horizontal line to the laundry sink ( you can use 1 1/2" but laundry sinks catch a lot of crud so I like 2"), install a 2 x 1 1/2 sanitary tee on it's back and put an AAV in top or a short pipe from the tee, and last if all install a 2 x 1/12 bushing and 1 1/2 p-trap for the laundry sink. Make sure the pipe has 1/4" per foot slope and you will be both legal and functional. The sanitary tee on it's back is a possible source of contention with some inspectors but, since there is no flow through the branch, I think it's legal and I know it works. |
http://i202.photobucket.com/albums/a...aneous/AAV.jpg |
Exactly. Except that looks like all 1 1/2" pipe, but the configuration is the same.
KC-The sanitary tee to the AAV is technically "on it's back", which is not allowed in the drainage system. Since the branch of the tee receives no flow, I consider it part of the vent system, but the ICC code is not clear on this. I've had some inspectors agree with me and others not. |
It needs to be at least 4" above the trap so it should fit under the sink.
Why do you think this would this be a bad idea? |
| All times are GMT -4. The time now is 04:54 AM. |
