Old 12-11-2011, 10:00 PM   #16
Need help from a plumber
were would the diss box be located from the tank.
ccampbell is offline   Reply With Quote
Old 12-11-2011, 10:24 PM   #17
call me E
TheEplumber's Avatar
Originally Posted by joecaption View Post
I've never heard of just one leach line unless it was some DIY job done 30 years ago.
Anything done in the past 20 years or so would have a d box and several lines running off from that point.
Most likly a plug any place from a vent line from when it plugged up last time to the tank, not from the tank to the leach field.
Why would waste water boil out of the tank then? Waste is entering the tank and not leaving.
Old 12-11-2011, 10:54 PM   #18
right i think its the port coming out of the tank or the leach line its just getting to it.
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 10:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 02:23 PM
Plumber installed thermal Expansion tank without adjusting pre-charge markwo Plumbing 2 01-21-2010 01:41 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 02:14 PM
