Old 12-11-2011, 07:02 PM   #1
Need help from a plumber
how full should a septic tank be
ccampbell is offline   Reply With Quote
Old 12-11-2011, 07:07 PM   #2
A septic tank stays full, The soilds fall to the bottom and the liquids over flow and run out to the leach field.
Why are you asking?
I septic tank needs to be pumped out about every 5 years depanding on usage due to the soilds filling up the bottom of the tank.
Old 12-11-2011, 07:12 PM   #3
i had the tank pumped 1 month ago so i could repair the line from the house to the tank. i replaced the pipe. ileft the lid and pipe uncovered so a plumber could inspect the work. and one day water was coming out of the tank lid
Old 12-11-2011, 07:24 PM   #4
Super Moderator
That sounds like a blockage from the tank to the leach field----see if you can locate the distribution box(s) and pull the lid(s)
Old 12-11-2011, 07:26 PM   #5
call me E
TheEplumber's Avatar
Or your outlet baffle may be plugged.
Old 12-11-2011, 07:29 PM   #6
Super Moderator
This is exactly why I like your answers---you know more than I do!
Old 12-11-2011, 07:29 PM   #7
the house was built in 1980 i was told it has 1 drain line. dose it have a box? the fluid seems to stay about 7 inches from the top of the tank but we have been using the water less till i find the problem
Old 12-11-2011, 07:33 PM   #8
call me E
Thanks Mike- just expounding on your wisdom
Old 12-11-2011, 07:37 PM   #9
i was also told that sludge could have broke loose and plugged the outlet line from when it was pumped. i have added tank treatment to the system. but i dont want to over flow the system again. the first time i put it in was about a week ago. should i wait a while longer or add somthing eles?
Old 12-11-2011, 08:19 PM   #10
what is a baffle?
Old 12-11-2011, 08:32 PM   #11
call me E
Originally Posted by ccampbell View Post
what is a baffle?
It is the tee that is located at the inlet and outlet of the tank. Take a look at this site. it has some good info to help understand your system
http://www.epa.gov/owm/septic/pubs/h...guide_long.pdf
Old 12-11-2011, 08:42 PM   #12
just loked at it so its not somthing that opens and closes. i guess if it dont have a box i just have to FIND the outlet cut a hole in the leach line and get a snake in there and goe down stream and to the tank to find the obstruction right?
Old 12-11-2011, 08:50 PM   #13
call me E
If you have only one leg in the field then you won't have a dist. box.
You should have a inspection hole in your tank to access the outlet tee/baffle. You can run a cable thru the tee and out to your drain field. You might have sludge or a soft plug like you mentioned earlier.
Old 12-11-2011, 09:05 PM   #14
ok i will try to find the other lid and go from there. i hope it is somthing like that and not a bad leach line. thanks for your tips
Old 12-11-2011, 09:49 PM   #15
I've never heard of just one leach line unless it was some DIY job done 30 years ago.
Anything done in the past 20 years or so would have a d box and several lines running off from that point.
Most likly a plug any place from a vent line from when it plugged up last time to the tank, not from the tank to the leach field.
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 10:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 02:23 PM
Plumber installed thermal Expansion tank without adjusting pre-charge markwo Plumbing 2 01-21-2010 01:41 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 08:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 02:14 PM
